New Project SZD 9 Bocian
RobertoP
Âge: 62 Balance
MessagePosté le: 25/09/2010 22:54    Sujet du message: New Project SZD 9 Bocian Répondre en citant
Hi All,
after the construction of Musger from Vincent's project I have decide to start with a new model, after various hypothesis I start with the design of SZD 9 Bocian. After about two months I have concluded my project. I have choice 4.7 scale that gives a model of about 3,85m. Here enclosed my design. Next week I start the cutting of various pieces.
Roberto
MessagePosté le: 26/09/2010 06:17    Sujet du message: Répondre en citant
Hi Roberto, nice project Very Happy it's very well that after a building from plan or kit, you are drawing your own plans [clap]
RobertoP
Âge: 62 Balance
MessagePosté le: 26/09/2010 10:45    Sujet du message: Répondre en citant
Dear Vincent,
is thanks to your projects that I learned to design my models, the Bocian is my second project my first was the Mucha 100.
Some other information about my Bocian:
Spanwith 3850mm
Wings area 87dm2
Tail surface 13 dm2
Estimated weight 4800 gr
Wing load 55gr/dm2
Wing profile MSRetro 13%-11%
Roberto
MessagePosté le: 26/09/2010 11:23    Sujet du message: Répondre en citant
Nice project we shall follow with much interest [clap]
Renato
Âge: 66 Vierge
MessagePosté le: 04/10/2010 19:14    Sujet du message: Re: New Project SZD 9 Bocian Répondre en citant
Hi Roberto.
I am very interested in your project, because I´m start to build the Bocian from a plan bought to Traplet pubblications. It is a 3 mts wingspan. I would like to known which wing profile you will use and how you will install the wing to the fuse.
Regards, Renato
RobertoP
Âge: 62 Balance
MessagePosté le: 04/10/2010 20:58    Sujet du message: Re: New Project SZD 9 Bocian Répondre en citant
« Renato » a écrit:
Hi Roberto.
Regards, Renato
Hi Renato,
the wing profile is the MS Retro 13% with an incidence of 2°. To connect the wings to fusolage I have decided to use a round bar of fiberglass. The same method used by Vincent on the Bergfalke.
Roberto
RobertoP
Âge: 62 Balance
MessagePosté le: 17/10/2010 21:15    Sujet du message: Répondre en citant
Hi All,
my construction is now started here enclosed some photos of my Bocian
Roberto
Âge: 80 Verseau
MessagePosté le: 18/10/2010 09:59    Sujet du message: Répondre en citant
Congratulations Roberto,
I think you may already stop. What you have built is a piece of art.
I will also follow very close your construction.
Bocian is an interesting project. Not many have been build. It is a different shape compared to the standard sailplanes.
Regards.
Harold
Âge: 76 Poissons
MessagePosté le: 19/10/2010 11:57    Sujet du message: Répondre en citant
Hello Roberto
Summer 2010 at Airfield of Czestochowa:
Bocian details for you:
Âge: 76 Poissons
MessagePosté le: 19/10/2010 12:00    Sujet du message: Répondre en citant
Other :
Âge: 76 Poissons
MessagePosté le: 19/10/2010 12:06    Sujet du message: Répondre en citant
And more
Âge: 76 Poissons
MessagePosté le: 19/10/2010 12:08    Sujet du message: Répondre en citant
The last
RobertoP
Âge: 62 Balance
MessagePosté le: 23/10/2010 19:51    Sujet du message: Répondre en citant
Hi Pierre many thanks for the photos are all interesting. Hi Harold thanks for the congratulation. Today I have concluded the rudders, here enclosed some photos. Now I start with thw elevator because to arrange the elevatore control system inside the fusolage is better to have the elevator.
I think to use the same method of control used by Vincent on MG 9A.
Roberto
RobertoP
Âge: 62 Balance
MessagePosté le: 01/11/2010 19:30    Sujet du message: Répondre en citant
Hi All,
my construction of Bocian is proceeding, the elevator is concluded. Now I have to decide the method of elevator control. I have some doubt, I don't know if choose the method used by Vincent on MG 9 or simply use two bowden with external connection to movable part of horizontal tail.
Your suggestions are very appreciated, many thanks in advance
Roberto
MessagePosté le: 01/11/2010 20:01    Sujet du message: Répondre en citant
Always very clean and perfect [clap] did you choice the color scheme?
RobertoP
Âge: 62 Balance
MessagePosté le: 01/11/2010 20:23    Sujet du message: Répondre en citant
Many thanks Vincent,
up today my idea is the scheme of the Bocian in the enclosed photo
Roberto
MessagePosté le: 01/11/2010 20:33    Sujet du message: Répondre en citant
Ok, I guess you know there is the photopack of this glider on the download zone
http://www.retroplane.net/forum/downloads.php?view=detail&df_id=203
RobertoP
Âge: 62 Balance
MessagePosté le: 01/11/2010 22:07    Sujet du message: Répondre en citant
Thanks Vincent,
already download, are the photos that give me the idea to project and built the Bocian, for me the colour and the painting scheme is beautiful.
roberto
Renato
Âge: 66 Vierge
MessagePosté le: 02/11/2010 04:15    Sujet du message: Répondre en citant
Hi Roberto
!!! Beautiful piece of art !!!
Renato
RobertoP
Âge: 62 Balance
Nouveau messagePosté le: 02/11/2010 22:18    Sujet du message: Simulation with XLRF5 Répondre en citant
Hi All,
today I have used the software XLRF5 to try to check the flight characteristics of Bocian with the profile MS retro 13%.
The wing incidence that I have chosen is of 2°.
In the two followings images it is possible to understand the with the CG placed at 67mm the model will fly at a speed of 12.5m/s that is 45 km/h. With the wing incidence of 2° the moment coefficient is zero.
In the enclosed diagram the max. glide ratio is about 28 at speed of 12.5m/s
Roberto
RobertoP
Âge: 62 Balance
Nouveau messagePosté le: 07/11/2010 20:19    Sujet du message: Répondre en citant
Hi All some other photos of my Bocian
Roberto
Nouveau messagePosté le: 08/11/2010 08:42    Sujet du message: Répondre en citant
Hi Roberto,
...looks really great! [clap]
I´m looking forward to see your Bocian airborne...
Paul ELLIS
Âge: 79 Verseau
Nouveau messagePosté le: 09/11/2010 19:14    Sujet du message: Répondre en citant
Beautiful workmanship Roberto [clap]
Paul
Un anglais en France
RobertoP
Âge: 62 Balance
Nouveau messagePosté le: 21/11/2010 23:10    Sujet du message: Répondre en citant
Hi All
today I have concluded the covering of fusolage, here enclosed two photos of work.
Roberto
Nouveau messagePosté le: 22/11/2010 11:21    Sujet du message: Répondre en citant
il n'y a pas à dire c'était un c'est beau planeur!
attention en Anglais: is the verry beautiful glidder!
Fauteuilaroulix in the Jabron river Valley! Embarassed
RobertoP
Âge: 62 Balance
Nouveau messagePosté le: 28/11/2010 17:15    Sujet du message: Répondre en citant
Hi All,
today I have conclude the structure of fin where the horizontal tail is fixed. The fin is made by a a shaped balsa block I have some doubt if is better to make some hole in order to reduce the weight on rear part of fuselage.
Roberto
Renato
Âge: 66 Vierge
Nouveau messagePosté le: 29/11/2010 01:00    Sujet du message: Répondre en citant
Hi Roberto. Beautifull work!!!
Is not a bad idea to reduce some weight in the tail. You could open some holes in the fin and the structure below the elevator, and refill the holes with foam, in order to mantaing the shape of the structure at the moment of cover it.
Renato
RobertoP
Âge: 62 Balance
Nouveau messagePosté le: 29/11/2010 21:17    Sujet du message: Répondre en citant
Thanks Renato,
good idea to use foam to fill the holes.
Roberto
RobertoP
Âge: 62 Balance
Nouveau messagePosté le: 12/12/2010 20:34    Sujet du message: Giorgio's Bocian Répondre en citant
Hi All,
also my dear friend Giorgio is working on my project of Bocian,
some photos of his work
Roberto
RobertoP
Âge: 62 Balance
Nouveau messagePosté le: 08/01/2011 23:00    Sujet du message: Répondre en citant
Hi All,
The construction of my Bocian is proceeding with the wings here enclose some photos of the right wing, now I need to start with the left wing.
Roberto
Page 1 sur 3
