RobertoP Fidèle Posteur
Posté le: 25/09/2010 21:54 Sujet du message: New Project SZD 9 Bocian |
Hi All,
after the construction of Musger from Vincent's project I have decide to start with a new model, after various hypothesis I start with the design of SZD 9 Bocian. After about two months I have concluded my project. I have choice 4.7 scale that gives a model of about 3,85m. Here enclosed my design. Next week I start the cutting of various pieces.
Roberto
Posté le: 26/09/2010 05:17 Sujet du message: |
Hi Roberto, nice project it's very well that after a building from plan or kit, you are drawing your own plans ![[clap]](images/smiles/Clap.gif)
Posté le: 26/09/2010 10:23 Sujet du message: |
Nice project we shall follow with much interest ![[clap]](images/smiles/Clap.gif) |
Renato Stagiaire Posteur
Posté le: 04/10/2010 18:14 Sujet du message: Re: New Project SZD 9 Bocian |
Hi Roberto.
I am very interested in your project, because I´m start to build the Bocian from a plan bought to Traplet pubblications. It is a 3 mts wingspan. I would like to known which wing profile you will use and how you will install the wing to the fuse.
Regards, Renato |
Posté le: 04/10/2010 19:58 Sujet du message: Re: New Project SZD 9 Bocian |
« Renato » a écrit: Hi Roberto.
Regards, Renato
Hi Renato,
the wing profile is the MS Retro 13% with an incidence of 2°. To connect the wings to fusolage I have decided to use a round bar of fiberglass. The same method used by Vincent on the Bergfalke.
Roberto |
Posté le: 17/10/2010 20:15 Sujet du message: |
Hi All,
my construction is now started here enclosed some photos of my Bocian
Roberto
Posté le: 18/10/2010 08:59 Sujet du message: |
Congratulations Roberto,
I think you may already stop. What you have built is a piece of art.
I will also follow very close your construction.
Bocian is an interesting project. Not many have been build. It is a different shape compared to the standard sailplanes.
Regards.
Harold |
DELRIEUPierre Psycho Posteur
Posté le: 19/10/2010 10:57 Sujet du message: |
Hello Roberto
Summer 2010 at Airfield of Czestochowa:
Bocian details for you:
Posté le: 19/10/2010 11:00 Sujet du message: |
Other :
Posté le: 19/10/2010 11:06 Sujet du message: |
And more
Posté le: 19/10/2010 11:08 Sujet du message: |
The last
Pierre |
Posté le: 23/10/2010 18:51 Sujet du message: |
Hi Pierre many thanks for the photos are all interesting. Hi Harold thanks for the congratulation. Today I have concluded the rudders, here enclosed some photos. Now I start with thw elevator because to arrange the elevatore control system inside the fusolage is better to have the elevator.
I think to use the same method of control used by Vincent on MG 9A.
Roberto
Posté le: 01/11/2010 18:30 Sujet du message: |
Hi All,
my construction of Bocian is proceeding, the elevator is concluded. Now I have to decide the method of elevator control. I have some doubt, I don't know if choose the method used by Vincent on MG 9 or simply use two bowden with external connection to movable part of horizontal tail.
Your suggestions are very appreciated, many thanks in advance
Roberto
Posté le: 01/11/2010 19:01 Sujet du message: |
Always very clean and perfect did you choice the color scheme?
Posté le: 01/11/2010 21:07 Sujet du message: |
Thanks Vincent,
already download, are the photos that give me the idea to project and built the Bocian, for me the colour and the painting scheme is beautiful.
roberto |
Posté le: 02/11/2010 03:15 Sujet du message: |
Hi Roberto
!!! Beautiful piece of art !!!
Renato |
Posté le: 02/11/2010 21:18 Sujet du message: Simulation with XLRF5 |
Hi All,
today I have used the software XLRF5 to try to check the flight characteristics of Bocian with the profile MS retro 13%.
The wing incidence that I have chosen is of 2°.
In the two followings images it is possible to understand the with the CG placed at 67mm the model will fly at a speed of 12.5m/s that is 45 km/h. With the wing incidence of 2° the moment coefficient is zero.
In the enclosed diagram the max. glide ratio is about 28 at speed of 12.5m/s
Roberto |
Posté le: 07/11/2010 19:19 Sujet du message: |
Hi All some other photos of my Bocian
Roberto
Walter Incurable Posteur
Posté le: 08/11/2010 07:42 Sujet du message: |
Hi Roberto,
...looks really great!
I´m looking forward to see your Bocian airborne...
Walter |
Paul ELLIS Fidèle Posteur
Posté le: 09/11/2010 18:14 Sujet du message: |
Beautiful workmanship Roberto
Paul
 Un anglais en France |
Posté le: 21/11/2010 22:10 Sujet du message: |
Hi All
today I have concluded the covering of fusolage, here enclosed two photos of work.
Roberto
Posté le: 22/11/2010 10:21 Sujet du message: |
il n'y a pas à dire c'était un c'est beau planeur!
attention en Anglais: is the verry beautiful glidder!
Fauteuilaroulix in the Jabron river Valley!
Posté le: 28/11/2010 16:15 Sujet du message: |
Hi All,
today I have conclude the structure of fin where the horizontal tail is fixed. The fin is made by a a shaped balsa block I have some doubt if is better to make some hole in order to reduce the weight on rear part of fuselage.
Roberto
Posté le: 29/11/2010 00:00 Sujet du message: |
Hi Roberto. Beautifull work!!!
Is not a bad idea to reduce some weight in the tail. You could open some holes in the fin and the structure below the elevator, and refill the holes with foam, in order to mantaing the shape of the structure at the moment of cover it.
Renato |
Posté le: 29/11/2010 20:17 Sujet du message: |
Thanks Renato,
good idea to use foam to fill the holes.
Roberto |
Posté le: 12/12/2010 19:34 Sujet du message: Giorgio's Bocian |
Hi All,
also my dear friend Giorgio is working on my project of Bocian,
some photos of his work
Roberto
Posté le: 08/01/2011 22:00 Sujet du message: |
Hi All,
The construction of my Bocian is proceeding with the wings here enclose some photos of the right wing, now I need to start with the left wing.
Roberto
