phoenix27 Stagiaire Posteur
Posté le: 17/04/2007 20:36 Sujet du message: Doppi in Romania :) |
My name is Márton Csaba, i'm from Transylvania. I would like to show some pictures of my Doppi. Thanks to my friend(who gives the ideea to build this plane), for all support. Oops. I have to change the size of the pictures.... They will arrive soon... |
Posté le: 17/04/2007 20:47 Sujet du message: |
Hello Márton, welcome on the forum
you are the first builder of Doppi from Romania ![[good]](images/smiles/good.gif)
Posté le: 17/04/2007 21:28 Sujet du message: The beginning |
Posté le: 17/04/2007 21:31 Sujet du message: The wing |
....step by step... slowly, but surely
Posté le: 17/04/2007 21:34 Sujet du message: The cockpit |
The bord with the instruments.....
Posté le: 17/04/2007 21:36 Sujet du message: And the plane 1st pic |
Posté le: 17/04/2007 21:38 Sujet du message: 2nd pict |
...with a little help from my friend
Posté le: 17/04/2007 21:43 Sujet du message: |
...and more will come  |
Stephan Psycho Posteur
Posté le: 18/04/2007 08:06 Sujet du message: |
Hi Márton
wellcome to the forum. I see that you are moving quite fast with your constrcution. Please update us with the advancement. Perhaps you want to open another thread telling us a little bit about modelbuilding and flying indeed in Romanie, or perhaps if Vincent accepts you are doing it just here.
Have fun
Stephan |
Posté le: 20/04/2007 17:49 Sujet du message: Help!! |
I can't weld the alu tubes for the cockpit. I tried so many ways but doesn't work. I tried the epoxy too, but still nothing.  |
loopingfred Incurable Posteur
Posté le: 20/04/2007 18:13 Sujet du message: |
Hi Marton,
What about the canopy we can see on one of the pictures above ?
That's not the one from your Doppi ?
Otherwise, what is your problem with the welding ? What are you using ?
Maybe the tube or what you are using to weld is not appropriated
Let us know, Vincent is now a master welder !
MORE BEERS!!!! |
Posté le: 20/04/2007 19:07 Sujet du message: |
Canopy in brass (laiton?) is more easy to solder, like this
Posté le: 20/04/2007 19:42 Sujet du message: |
Ooppss sorry, missed a part !
If you are using aluminium tubes, that harder to weld together without the right tools.
As Vincent suggested, brass tube are much more easier to sold together !
But as Stepahn said, I too can confirm that you can glue alu tubes together with epoxy. Hold the tubes together before gluing with a wire (or wooden pins) inside the tube junctions.
Hope this help.
MORE BEERS!!!! |
Posté le: 20/04/2007 20:33 Sujet du message: |
Thanks a lot. I will try. My od canopy... yes... You know.. childrens.. I forgot on my table, and my chilrens found it.... and played with it... So I have to make another one. I will use the epoxy glue. |
Posté le: 20/04/2007 21:05 Sujet du message: The brake |
Posté le: 20/04/2007 21:08 Sujet du message: |
The right wing almost ready...
Posté le: 20/04/2007 21:18 Sujet du message: |
« phoenix27 » a écrit: I will use the epoxy glue.
Don't forget to take a fast one (5 minutes) otherwise it will flow away from the place where it should stay. Perhaps you add also some microballons ( do not know the right english term, something to make epoxy thicker)
Stephan |
Posté le: 21/04/2007 08:47 Sujet du message: |
Ok thanks. I will try today.
Tonight a worked with the triangles ( ) What can I say.... You need selfcontrol to do that
Posté le: 21/04/2007 09:00 Sujet du message: |
Oh.. I forgot to say that I have to finish till thursday, because friday will be the meetingday of the romanian modelers at Sebes. I want to show them something interesting  |
Posté le: 22/04/2007 09:10 Sujet du message: |
I will use oracover (white), and I(hope) will finish. Now I work with the canopy. |
Posté le: 22/04/2007 10:10 Sujet du message: |
Good luck mate !
And don't forget the pictures !
MORE BEERS!!!! |
Marco Serafini Stagiaire Posteur
Posté le: 23/04/2007 20:09 Sujet du message: |
ha oui Marco c'est ton Dopp, mais ce n'est pas du désordre un Dopp dans la cuisine, c'est naturel, chez tous les bons modélistes, il y a des outils dans le salon, du plastique dans le four, de la cyano dans le frigidaire, du balsa dans la chambre....  |
Posté le: 25/04/2007 07:32 Sujet du message: |
Question: What kind of paint is supported by oracover? I have 2 days to finish  |
Posté le: 25/04/2007 10:01 Sujet du message: |
Hi Marton,
You can use any paint with Oracover.
For me, I go to the DIY store and take any paint. Usually I take the "one coat" type paint. No need for car paint and so on, "normal" wall paint do it.
MORE BEERS!!!! |
Posté le: 25/04/2007 10:05 Sujet du message: |
ok. Here is my pilot, on his place  |
Posté le: 25/04/2007 13:05 Sujet du message: |
Wellcome Marton,Where is the second pilote the " Meister "? . So I confirm the answer of Fred regarding painting. No special paint
