Doppi in Romania :)
phoenix27
MessagePosté le: 17/04/2007 19:36    Sujet du message: Doppi in Romania :) Répondre en citant
My name is Márton Csaba, i'm from Transylvania. I would like to show some pictures of my Doppi. Thanks to my friend(who gives the ideea to build this plane), for all support. Oops. I have to change the size of the pictures.... They will arrive soon...
MessagePosté le: 17/04/2007 19:47    Sujet du message: Répondre en citant
Hello Márton, welcome on the forum Very Happy
you are the first builder of Doppi from Romania [good]
phoenix27
MessagePosté le: 17/04/2007 20:28    Sujet du message: The beginning Répondre en citant
phoenix27
MessagePosté le: 17/04/2007 20:31    Sujet du message: The wing Répondre en citant
....step by step... slowly, but surely Very Happy
phoenix27
MessagePosté le: 17/04/2007 20:34    Sujet du message: The cockpit Répondre en citant
The bord with the instruments.....
phoenix27
MessagePosté le: 17/04/2007 20:36    Sujet du message: And the plane 1st pic Répondre en citant
phoenix27
MessagePosté le: 17/04/2007 20:38    Sujet du message: 2nd pict Répondre en citant
...with a little help from my friend Very Happy
phoenix27
MessagePosté le: 17/04/2007 20:43    Sujet du message: Répondre en citant
...and more will come Wink
MessagePosté le: 18/04/2007 07:06    Sujet du message: Répondre en citant
Hi Márton
wellcome to the forum. I see that you are moving quite fast with your constrcution. Please update us with the advancement. Perhaps you want to open another thread telling us a little bit about modelbuilding and flying indeed in Romanie, or perhaps if Vincent accepts you are doing it just here.
Have fun
phoenix27
MessagePosté le: 20/04/2007 16:49    Sujet du message: Help!! Répondre en citant
I can't weld the alu tubes for the cockpit. I tried so many ways but doesn't work. I tried the epoxy too, but still nothing. Crying or Very sad
loopingfred
Âge: 50 Gémeau
MessagePosté le: 20/04/2007 17:13    Sujet du message: Répondre en citant
Hi Marton,
What about the canopy we can see on one of the pictures above ? [humm]
That's not the one from your Doppi ?
Otherwise, what is your problem with the welding ? What are you using ?
Maybe the tube or what you are using to weld is not appropriated [humm]
Let us know, Vincent is now a master welder ! Very Happy
MORE BEERS!!!!
MessagePosté le: 20/04/2007 17:24    Sujet du message: Re: Help!! Répondre en citant
Márton
I do not realy understand, some pictures before there was the canopy finished, I thought at least. What happens to this one [humm]
I have assembled the tubes of my canopy with fast epoxy, always putting a littel piece of wire into both tubes. You have to clean each side of the alu tube then it will work, believe me, several peoples have already used this methode.
Cheers
MessagePosté le: 20/04/2007 18:07    Sujet du message: Répondre en citant
Canopy in brass (laiton?) is more easy to solder, like this
loopingfred
Âge: 50 Gémeau
MessagePosté le: 20/04/2007 18:42    Sujet du message: Répondre en citant
Ooppss sorry, missed a part !
If you are using aluminium tubes, that harder to weld together without the right tools.
As Vincent suggested, brass tube are much more easier to sold together !
But as Stepahn said, I too can confirm that you can glue alu tubes together with epoxy. Hold the tubes together before gluing with a wire (or wooden pins) inside the tube junctions.
Hope this help.
MORE BEERS!!!!
phoenix27
MessagePosté le: 20/04/2007 19:33    Sujet du message: Répondre en citant
Thanks a lot. I will try. My od canopy... yes... You know.. childrens.. I forgot on my table, and my chilrens found it.... and played with it... So I have to make another one. I will use the epoxy glue.
phoenix27
MessagePosté le: 20/04/2007 20:05    Sujet du message: The brake Répondre en citant
phoenix27
MessagePosté le: 20/04/2007 20:08    Sujet du message: Répondre en citant
The right wing almost ready...
Nouveau messagePosté le: 20/04/2007 20:18    Sujet du message: Répondre en citant
Don't forget to take a fast one (5 minutes) otherwise it will flow away from the place where it should stay. Perhaps you add also some microballons ( do not know the right english term, something to make epoxy thicker)
phoenix27
Nouveau messagePosté le: 21/04/2007 07:47    Sujet du message: Répondre en citant
Ok thanks. I will try today.
Tonight a worked with the triangles ( [argh] ) What can I say.... You need selfcontrol to do that Laughing
phoenix27
Nouveau messagePosté le: 21/04/2007 08:00    Sujet du message: Répondre en citant
Oh.. I forgot to say that I have to finish till thursday, because friday will be the meetingday of the romanian modelers at Sebes. I want to show them something interesting Very Happy
Nouveau messagePosté le: 21/04/2007 09:00    Sujet du message: Répondre en citant
Shocked wohw, really challenging goal, You take what as covering, because if you need to paint, no chance to to the job till friday [humm]
phoenix27
Nouveau messagePosté le: 22/04/2007 08:10    Sujet du message: Répondre en citant
I will use oracover (white), and I(hope) will finish. Now I work with the canopy.
loopingfred
Âge: 50 Gémeau
Nouveau messagePosté le: 22/04/2007 09:10    Sujet du message: Répondre en citant
Good luck mate !
And don't forget the pictures !
MORE BEERS!!!!
Marco Serafini
Nouveau messagePosté le: 23/04/2007 18:59    Sujet du message: Répondre en citant
Canopy in brass (laiton?) .......
Hei Vincent, ma femme a vu la photo et a dit qu'est ce désordre dans ma cuisine!! [non] Confused
"taire et sembler des stupides il est mieux que parler et enlever chaque doute..."
Nouveau messagePosté le: 23/04/2007 19:09    Sujet du message: Répondre en citant
ha oui Marco c'est ton Dopp, mais ce n'est pas du désordre un Dopp dans la cuisine, c'est naturel, chez tous les bons modélistes, il y a des outils dans le salon, du plastique dans le four, de la cyano dans le frigidaire, du balsa dans la chambre.... Laughing
phoenix27
Nouveau messagePosté le: 25/04/2007 06:32    Sujet du message: Répondre en citant
Question: What kind of paint is supported by oracover? I have 2 days to finish Confused
Nouveau messagePosté le: 25/04/2007 06:54    Sujet du message: Répondre en citant
Sorry, Márton, no clou, perhaps you have a look at the Oracover Homepage. Don't give Laughing
loopingfred
Âge: 50 Gémeau
Nouveau messagePosté le: 25/04/2007 09:01    Sujet du message: Répondre en citant
Hi Marton,
You can use any paint with Oracover.
For me, I go to the DIY store and take any paint. Usually I take the "one coat" type paint. No need for car paint and so on, "normal" wall paint do it.
Very Happy
MORE BEERS!!!!
phoenix27
Nouveau messagePosté le: 25/04/2007 09:05    Sujet du message: Répondre en citant
ok. Here is my pilot, on his place Very Happy
Nouveau messagePosté le: 25/04/2007 12:05    Sujet du message: Répondre en citant
Wellcome Marton,Where is the second pilote the " Meister "? Laughing . So I confirm the answer of Fred regarding painting. No special paint
