Laurent Beldame Maniaco Posteur
Posté le: 24/07/2008 14:24 Sujet du message: |
Therefore we all assume that Mrs Williams (certainly an holy spouse!)knows where the iron is ...
L
loopingfred Incurable Posteur
Posté le: 24/07/2008 14:38 Sujet du message: |
Well, she knows now that he can use it !
MORE BEERS!!!! |
cw Fidèle Posteur
Posté le: 28/07/2008 21:16 Sujet du message: |
Madame Williams knows where everything is...!
Moving to the front of the fuselage now:
The outer planking is covered with car body filler and sanded roughly to shape...
We have to start removing the temporary formers... (Note glassing in between the formers to hold the planking together)
Note the hole on the former to allow a finger to be inserted to pull it out!
Cleaning up with a power file..
Ready now to fully glass the interior...
 cw |
patte de loup Maniaco Posteur
Posté le: 28/07/2008 21:57 Sujet du message: |
Hi Chris,
It can't be more clear
Is the car body feeler named "Sinthofer ". Or what's it ? Polyester resin?
Soft? Easy to sand?
 un "prédateur" des pentes de France et de Navarre |
Arnaudo Fidèle Posteur
Posté le: 28/07/2008 22:24 Sujet du message: |
Hello Chris,
Very pleased to see you on the forum. Having a look at your new building, reminds me the begining of the fuselage of the Minimoa. Building like ships.
Hope to see you one day, may be in ireland. If i succeed to build the Minimoa in lest than 4 years
Arnaud
 Minimoa Made in France ! |
cw Fidèle Posteur
Posté le: 28/07/2008 23:22 Sujet du message: |
Pat, over here it is called this. It is easy to sand soon after it cures (5mins) but gets harder the longer you leave it...
Arnaud, it would be good to see your Minimoa in Ireland. 4 years is a long time, maybe this build log for my new Minimoa will help...?
http://www.rcgroups.com/forums/showthread.php?t=660340&highlight=minimoa
 cw |
Posté le: 29/07/2008 14:51 Sujet du message: |
Chris,
I am building the 1/4 scale model i bought threw traplet. So this is your plan
Started the log on retroplane.net on 02/2006
Arnaud
cw Fidèle Posteur
Posté le: 01/08/2008 21:08 Sujet du message: |
Keep building Arnaud...!
Now we must properly glass the inside of the fuselage (note card template)
A bit more filler on the outside to soothe the soul
Now to play with the retract...
Making the retract doors...2 pieces of 0.75mm plywood are laminated together with epoxy and taped to the bottom of the fuselage to get the correct shape...
 cw |
cw Fidèle Posteur
Posté le: 07/08/2008 23:26 Sujet du message: |
Now the doors are fitted and held shut with torsion springs...
Time now to check on progress...
Starting on the wing/fuselage fairing...
More of the same...
 cw |
GuillaumeG Accro Posteur
Posté le: 08/08/2008 17:29 Sujet du message: |
Hi Chris,
it's still nice and quick as usual! Your building is very efficient! I would like to ask you if you could make some close-up pictures of your retract system, and of the doors springs.
Keep going!
Thanks  |
cw Fidèle Posteur
Posté le: 08/08/2008 23:38 Sujet du message: |
Gillaume, I should say that this build started earlier this year back in March and we are not up to the present date yet...!
The door hinging and springing I have copied from a Graupner Swift kit I built a few years ago. The doors have a brass tube epoxied to them and the retaining rods run through tubes in the fuselage so that they can be easily removed at any time. The torsion springs are just fine piano wire, also retained by small brass tubes as shown by the black arrows...
The retract is a standard Multiplex item...
 cw |
Posté le: 09/08/2008 11:20 Sujet du message: |
Thank you Chris that's clear (the same system is used in F3k for hinges of rudder for example).
Last question, how the doors remains "enough" opened, as it's the wheel going down which pushes them? |
cw Fidèle Posteur
Posté le: 09/08/2008 21:10 Sujet du message: |
Gillaume, the doors rest against the retract legs: I have not yet worked out a method to make them open wider...
Meanwhile, before we can make the wing fairing over the centre of the wing, we must first make up the canopy frame to create the correct shape.
First, the starboard (right hand) rail must be hinged up...(Pressing the rail against the hinges marks the masking tape so that you know exactly where to drill the holes)
Now the rest of the frame can be made. The rear former is made up from laminations of .75mm plywood to obtain the correct shape...
The joints are reinforced with hardwood, to be trimmed up later
Drilling the holes for the locating peg to ensure that the canopy closes in the same place every time
Now the joints are reinforced with thin piano wire pegs...
 cw |
cw Fidèle Posteur
Posté le: 14/08/2008 22:49 Sujet du message: |
Now that the canopy frame is assembled, we can start to make the wing/fuselage fairing...
1st, we make up blanks from 12mm balsa sheet
The balsa blanks are glued to a .75mm plywood base
The wood is sanded roughly to shape, and body filler is applied to get it all to the final smooth shape
et voila...
 cw |
cw Fidèle Posteur
Posté le: 17/08/2008 21:53 Sujet du message: |
Now the outer wing panels must be made...
1st job: the wing joiner box (2 x 14mm flat brass boxes)
The wing box must be made while it is attached to the centre wing panel to ensure that the steel blades line up properly
Now we must make sure that the root rib lines up properly too
Once the bottom of the wing panel has been sheeted, it will be placed on these supports to keep it straight and true
 cw |
