RobertoP Fidèle Posteur
Posté le: 08/01/2011 23:12 Sujet du message: |
Hi All,
My friend Giorgio is working faster than me here enclose some photos of his Bocian.
Roberto
erwan Psycho Posteur
Posté le: 09/01/2011 11:04 Sujet du message: |
Very good job. |
Posté le: 09/01/2011 13:11 Sujet du message: |
pat'
Posté le: 09/01/2011 14:26 Sujet du message: |
Très beau planeur
Posté le: 09/01/2011 15:16 Sujet du message: |
Bocianissimmo ! |
plu ronan Incurable Posteur
Posté le: 09/01/2011 17:40 Sujet du message: |
beau boulot |
michel Serial Posteur
Posté le: 09/01/2011 19:07 Sujet du message: |
superbe |
Posté le: 23/01/2011 16:50 Sujet du message: |
Hi All,
many thanks to all, also the construction of my Bocian is proceeding slowly but proceeding, here enclose two photos, now I have to start with air brake.
Roberto
Posté le: 23/01/2011 18:08 Sujet du message: |
Good job, the main spar seems rather strong ! |
Posté le: 17/03/2011 22:19 Sujet du message: |
Hi All,
Some other photos of wings of my Bocian
Roberto
Walter L. Maniaco Posteur
Posté le: 18/03/2011 20:52 Sujet du message: |
Congratulations Roberto,
it looks very nice; properly built!
Walter |
Posté le: 10/04/2011 18:10 Sujet du message: |
Hi all,
other photos of my Bocian, now I need to build the alierons.
Roberto
Posté le: 12/05/2011 22:07 Sujet du message: |
Hi All,
also the alierons are now concluded now I need to start with the cockpit.
Roberto
Grandemago Stagiaire Posteur
Posté le: 12/05/2011 22:20 Sujet du message: |
Molto bello Roberto, complimenti per la precisione e pulizia del lavoro.. |
Posté le: 18/05/2011 21:09 Sujet du message: |
Hi All again,
after the wings, I started with the cockpit, following the construction method indicated by Vincent for the Musger.
Now I start with the frames construction considering that the cockpit is composed of three parts: the fixed ahead part, the central part hinged and the rear sliding part.
Roberto
ZED Apprenti Posteur
Posté le: 20/05/2011 12:42 Sujet du message: |
Hi Roberto !
Congratulations for your wonderfull job !!
I'm doing a SZD9 bocian too, but 100 cm width ...
Then, a bit smaller !
A+ |
caralp_laurent Psycho Posteur
Posté le: 20/05/2011 13:50 Sujet du message: |
Hi !
Good, it's beautiful
Sénèque |
Posté le: 20/05/2011 19:01 Sujet du message: |
Posté le: 21/05/2011 23:21 Sujet du message: |
Hi All,
many thanks to All for the congratulations to my work, now some photos of mock-up of cockpit in order to try to take the correct dimensions of the frames. Now I need to think an arrangement to make the rear part of cockpit sliding, but it is not so easy.
Roberto
Posté le: 22/05/2011 22:01 Sujet du message: |
Hi again,
Two photos of rear sliding cockpit
Roberto
Posté le: 01/06/2011 20:52 Sujet du message: |
Hi Roberto !
Let's have a look : 100 cm width ...
A micro Bocian
Perhaps a day, i will take the time to build a much bigger one as you !
Bye
Z.
Posté le: 03/06/2011 17:38 Sujet du message: |
Hi Zed,
The Bocian is a beautiful subject for all scales and dimensions, many compliments for your mini Bocian
Roberto |
Posté le: 26/06/2011 23:07 Sujet du message: |
Hi All,
Some photos of cockpit of my Bocian with the pilots
Roberto
Posté le: 29/06/2011 22:32 Sujet du message: |
Wahou ! nice roberto !
it changes the look with these pilots !
Mine is too small for that :
Posté le: 03/07/2011 07:50 Sujet du message: |
Hi Zed,
your mini Bocian and mini JP are wery beutiful models many compliments for your work.
Roberto |
Posté le: 17/08/2011 21:01 Sujet du message: |
Hi All,
Now the fuselage and the wings are painted, here enclosed some photos of fuselage, the paint of wings is not yet ready for moving.
Roberto
Posté le: 23/08/2011 19:17 Sujet du message: |
Hi All,
other photos of my Bocian.
Roberto
GARCIA Psycho Posteur
Posté le: 23/08/2011 20:50 Sujet du message: |
c'est beau!!!
José |
Posté le: 26/08/2011 23:16 Sujet du message: |
Hi All,
the Bocian on the Bocian
Roberto
Posté le: 27/08/2011 13:50 Sujet du message: |
