RHONSPERBER 1:3
MessagePosté le: 10/01/2011 19:41    Sujet du message: Répondre en citant
Hello !
Splendid Chris !
[clap] [clap]
MessagePosté le: 10/01/2011 21:17    Sujet du message: Répondre en citant
magnifique [clap]
cw
Âge: 77 Sagittaire
MessagePosté le: 21/03/2011 15:43    Sujet du message: Répondre en citant
At last...! I have now completed the video for Rhonsperber Very Happy
http://www.youtube.com/watch?v=LLQDMfmrWng
cw
Âge: 79 Verseau
MessagePosté le: 21/03/2011 18:21    Sujet du message: Répondre en citant
Dear Chris,
Again, an exceptional video. HD quality.
Every time you increase the quality level.
Also the flight is beautiful. Even with such a weight. Maybe it is even flying better with that load.
But I think that your slope do have an excellent efficiency.
Congratulations.
MessagePosté le: 21/03/2011 18:51    Sujet du message: Répondre en citant
Big is beautiful, the bigger it is, the better it flies? Nice video [clap]
Walter L.
MessagePosté le: 21/03/2011 18:57    Sujet du message: Répondre en citant
Hi Chris,
obviously you have chosen the wrong music for your video....
In germany nobody can see (and hear) it because of the music from UMG.
Regards
GuillaumeG
Âge: 41 Vierge
MessagePosté le: 21/03/2011 19:37    Sujet du message: Répondre en citant
Yes impossible to see it in Germany! Please do something Chris [amen]
cw
Âge: 77 Sagittaire
MessagePosté le: 21/03/2011 21:24    Sujet du message: Répondre en citant
Yes, it's strange how our Germans friends are blocked out. I will upload version II with 100% instead of 50% my own music...
The problem is: I can make gliders or I can make music, but I do not have time to make both Very Happy
cw
Walter L.
MessagePosté le: 21/03/2011 23:56    Sujet du message: Répondre en citant
If there no other possibility, let us enjoy "silent flight"....
cw
Âge: 77 Sagittaire
MessagePosté le: 23/03/2011 00:46    Sujet du message: Répondre en citant
OK, this version should work in Germany...
http://www.youtube.com/watch?v=-Fvigk4eUZg
cw
MessagePosté le: 25/03/2011 20:59    Sujet du message: Répondre en citant
Very Happy it works, great pictures, nice slope and what a realistic flight [good]
MessagePosté le: 25/03/2011 22:48    Sujet du message: Répondre en citant
[good] vidéo Laughing
MessagePosté le: 26/03/2011 08:45    Sujet du message: Répondre en citant
Danke Chris,
ein Traum von Rhönsperber und ein Spitzenvideo [clap] [clap]
Achim55
Âge: 70 Vierge
MessagePosté le: 30/03/2011 10:41    Sujet du message: Répondre en citant
Hi Chris,
great job, well done [amen]
Greetings from Lippe/Germany
Achim
Beat
Âge: 64 Scorpion
MessagePosté le: 30/04/2011 17:02    Sujet du message: Répondre en citant
Hi Chris
Pleasing [bave]
I love you planes and the great vid's. Even my wife likes em - and she's normaly not so pleased about my hobby with 25 h daily in the hangar Very Happy .
As I am always in research of everything about the Rhönsperber, i have the master question here: Do plan to make plans for the plane ? Very Happy Very Happy Very Happy
or place tech specs (profiles / templates / etc.) at demand Rolling Eyes
Anyway, keep on - your work rocks!
Cheers
Beat
www.segelflugmodell.ch
cw
Âge: 77 Sagittaire
MessagePosté le: 30/04/2011 17:50    Sujet du message: Répondre en citant
Beat, I drew the Rhonsperber in Illustrator, but I am a novice in CAD, so the drawings are pretty rough and not always updated. I have used my usual wing sections (HQ35/15-12). That said, anyone who wants a copy is most welcome...
cw
MessagePosté le: 01/05/2011 08:27    Sujet du message: Répondre en citant
Chris
you are sure that it is HQ 35-15 [humm] because in no data base I can find this profile, however there is a 30-15 [humm]
Cheers
cw
Âge: 77 Sagittaire
MessagePosté le: 01/05/2011 08:50    Sujet du message: Répondre en citant
Stephan, it is a fairly simple matter to modify the the thickness of the profile in either Compufoil or Profili...
cw
Nouveau messagePosté le: 01/05/2011 08:53    Sujet du message: Répondre en citant
Chris
this means you took the 35-14, however you changed the thicknes to 15% [humm]
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 01/05/2011 10:17    Sujet du message: Répondre en citant
Yes, Stephan, that is correct... The reason for changing the thickness is to achieve a compromise between the appearance of the full size (always thick!)
and getting a model that will perform as efficiently as possible, especially on the hill, where this can be very important.
My models are always 12% thick at the wing tip, but vary at the root depending on the decisions I make at the time. Thus the Bergfalke is 12% at the root (because it is small) and most of the larger models are 14 or 15%...
Here you can compare the model with the full-size:
cw
Beat
Âge: 64 Scorpion
Nouveau messagePosté le: 01/05/2011 10:24    Sujet du message: Répondre en citant
Hi Chris
I'm also a bit confused about the HQ35-15/12.
On Dr. Quabecks page (http://www.hq-modellflug.de/) there is no HQ of this type anymore. He has now classified his profiles as follows:
» Freeflight (no RC) HQF-...,
» Flaps HQW-...,
» Oldtimer HQ/Oldy-...
» Flying Wings HQ/S-...
» für Winglets (low Re-Number) HQ/Winglet
» für dynamische Segler/Großsegler HQ/DS-...
» für Akrosegelflugmodelle HQ/ACRO-...,
Additionaly i have an old Book from the 80's where he has some HQ 35/xx series in (but it's 30 Jears old Embarassed )
Could you send me coordinates from your used profile that i can compare with my data (any format is welcome)
(I think this works via private Mail, but i never used it therefore. Otherwise you could send me a message via my website and copy the data into the text.)
However, i will have to decide between the HQ35-15 to HQ35-12 layout and the MS 535-1 to MS535-3v version on the other side for my 1:3,5 Rhönsperber somehow.
Many thank in advance
Cheers,
Beat
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 01/05/2011 11:21    Sujet du message: Répondre en citant
Beat, E-mail sent...
This profile was developed about 30 years ago by Mr Quabeck, specifically for scale gliders. Regardless of how efficient it is, you can build a flat wing (no twist) and end up with a wing that very SAFE at low speed, that is to say it has no bad behavior at all, a very important consideration with a scale glider that has many hours of work in it Cool
cw
Beat
Âge: 64 Scorpion
Nouveau messagePosté le: 02/05/2011 14:43    Sujet du message: Répondre en citant
Hi Chris
I didnt receive the Email! Did you send here by PM or via my Website?
Could you resend evtualy, please?
thanksalot
Beat
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 02/05/2011 15:00    Sujet du message: Répondre en citant
Beat, I sent it here: beat.galliker@bluewin.ch
cw
Beat
Âge: 64 Scorpion
Nouveau messagePosté le: 03/05/2011 11:55    Sujet du message: Répondre en citant
Hi Chris
Beat Galliker forwarded it to me! I have the Profile drawing now.
Will compare it next days.
Thanks again
Beat
Page 2 sur 2
