cw Accro Posteur
Posté le: 21/11/2010 18:52 Sujet du message: RHONSPERBER 1:3 |
Here is a quick look at my new project, the Rhonsperber, built to 3rd scale.
Maintenent, le premier vol...!
cw |
Posté le: 21/11/2010 18:57 Sujet du message: |
nice congratulations for this job
impatient to watch the HD mowie
erwan Psycho Posteur
Posté le: 21/11/2010 19:00 Sujet du message: |
So quick and beautiful
regards
Erwan |
Posté le: 21/11/2010 19:10 Sujet du message: |
Very nice indeed,another lovely gull winged sailplane
"Ah, ces ailes en mouette..." |
Posté le: 21/11/2010 20:51 Sujet du message: |
Posté le: 21/11/2010 21:21 Sujet du message: |
Hello !
Nice job !
GuillaumeG Accro Posteur
Posté le: 21/11/2010 21:45 Sujet du message: |
Congrats Chris! She's beautiful!! You didn't put enough pictures of the building
Waiting to see the first flight! |
Posté le: 22/11/2010 09:29 Sujet du message: |
How did you obtain the realistic colour of the covering unless it is secret ?? |
Posté le: 22/11/2010 10:58 Sujet du message: |
Hello Chris,
Again an interesting new project.
In the past you were building fast, now you are building with the same speed as the light.
No detail pictures of the construction?
Scale 1/3, is fine. In understand, limited by the size of your garden.
Expected weight? Still possible to throw alone on the slope?
First flight for next WE?
Regards.
Harold |
Posté le: 22/11/2010 11:25 Sujet du message: |
Very beautiful.
1er flight ?
Rusjan Apprenti Posteur
Posté le: 22/11/2010 13:52 Sujet du message: Rhonsperber |
Speechless .... can't wait to see that Go-pro in action...
Regards !
Uroš |
czirh Accro Posteur
Posté le: 22/11/2010 17:19 Sujet du message: |
Süperrr...........
Cem Zırh
Fafnir |
tuzkanh Stagiaire Posteur
Posté le: 22/11/2010 20:18 Sujet du message: |
Hakan Tuzkan
Ankara/Türkiye |
cw Accro Posteur
Posté le: 22/11/2010 22:25 Sujet du message: |
Messieurs, I did not put up the building pics because it is very much the same as the Steinadler and the Flamingo...
No secret, Marc, it is Antique Solartex
Model is not too heavy at 10kg, should be easy to launch by hand
Here are a few more details: the drop-off wheels were made by my good friend Barry
cw |
Posté le: 22/11/2010 22:43 Sujet du message: |
The antique solartex doesn't look too much yellow, you have varnished it? |
cw Accro Posteur
Posté le: 22/11/2010 23:57 Sujet du message: |
I have used my standard procedure:
1: 2 coats of 2-pack clear lacquer over entire wing
2: Sand surface wet with 800 paper
3: Apply 1 coat of satin lacqeur
4: Mask out open structure areas, flat again, and apply trim colours
cw |
Wolfgang Maniaco Posteur
Posté le: 23/11/2010 07:52 Sujet du message: |
Hi Chris
The velocity you have built it is your standard too - 4 months or so???
Did you take a HQ Profile ?? or another one?? |
cw Accro Posteur
Posté le: 23/11/2010 21:59 Sujet du message: |
Yes, Wolfgang, HQ35/15 root-35/12 tip
cw |
cw Accro Posteur
Posté le: 11/12/2010 21:15 Sujet du message: |
Today, the temperature briefly rose above freezing! The Rhonsperber has flown
cw |
Posté le: 11/12/2010 21:17 Sujet du message: |
Great |
Posté le: 11/12/2010 21:31 Sujet du message: |
Posté le: 11/12/2010 22:19 Sujet du message: |
Very nice indeed Congratulations |
Posté le: 12/12/2010 13:41 Sujet du message: |
Gratulation zu diesem tollen Modell
PS. Und immer weiche Landungen |
Posté le: 12/12/2010 17:58 Sujet du message: |
Great Chris
Next up now, roughly in the same colour
mat2verre Maniaco Posteur
Posté le: 13/12/2010 22:10 Sujet du message: |
A ce rythme de construction, ça ne s'appelle plus un atelier, mais un ermitage!!!!
Nice flights!
Mat
czirh Accro Posteur
Posté le: 14/12/2010 20:22 Sujet du message: |
Congratulations.............
Cem Zırh
Fafnir |
cw Accro Posteur
Posté le: 09/01/2011 22:43 Sujet du message: |
At last...! Some nice weather for White Sheet. The Rhonsperber had a comprehensive airing today: here are some pics...
cw |
caralp_laurent Psycho Posteur
Posté le: 10/01/2011 17:20 Sujet du message: |
Bravo Chris !
Lolométéo
Sénèque |
Posté le: 10/01/2011 17:38 Sujet du message: |
dito Lolo +1x
michel Serial Posteur
Posté le: 10/01/2011 19:07 Sujet du message: |
, la classe |
