Rusjan Apprenti Posteur
Posté le: 24/05/2010 17:39 Sujet du message: Minimoa 1:2.5 |
Here we go again ... This time even bigger and for sure more scale ...
Current condition...
looking rather small at 2.8m fuselage ...
Regards !
Uroš |
Posté le: 11/06/2010 01:42 Sujet du message: Mninmoa ! |
Some work was done on the elevator ...
from the side...
1200mm ...
Regards !
Uroš |
Posté le: 11/06/2010 05:25 Sujet du message: |
Hi Uroš,
Very clean what will be your choice for the color scheme? the same HB282 or another? |
Posté le: 11/06/2010 06:52 Sujet du message: |
Nice work, the Minimoa is always welcome such a mythic glider
personal drawings or enlarged plans ? A scale masterpiece this time !!  |
Posté le: 11/06/2010 08:33 Sujet du message: Minimoa ! |
« VincentB » a écrit: Hi Uroš,
Very clean ![[good]](images/smiles/good.gif) what will be your choice for the color scheme? the same HB282 or another?
As a tribute to 1:3.5 (RIP) it will be hb-282 design, but this time covered with oratex and painted...
Regards !
Uroš |
Posté le: 11/06/2010 09:41 Sujet du message: |
and with the right canopy you'll have to mould ???? I have some nice pictures of the internal settlement and many others if you need... I made one HB 282 at 1:4 scale  |
cw Accro Posteur
Posté le: 11/06/2010 18:51 Sujet du message: |
RIP, Uroš...?
 cw |
Posté le: 18/06/2010 14:32 Sujet du message: Minimoa ! |
Some more work done on the rudder ....
on the fuselage...
wondering if this all together is to BIG ....
just the right size ...
Regards !
Uroš |
Peter64 Maniaco Posteur
Posté le: 18/06/2010 20:53 Sujet du message: |
Hallo Uros,
nice rudder, good work .
Greetings
Peter |
Posté le: 19/06/2010 14:26 Sujet du message: |
Congratulations  |
Olivier Fidèle Posteur
Posté le: 19/06/2010 16:21 Sujet du message: |
Huuuuuuuuuuuuuuuge !!
What is the weight ?
 La Vie c'est un truc de DIINGUES !!  |
Posté le: 19/07/2010 19:04 Sujet du message: Minimoa ! |
Some more progress on inner wing section ....
Ribs...
Template...
It's easy with fixed ribs...
And the result ...
2.6m ...
Still missing 2 meters on each side ...
Regards !
Uroš |
Posté le: 19/07/2010 21:27 Sujet du message: |
Nice work but why so many spars on the inner wing? (according to the scale appearance?) ![[humm]](images/smiles/humm.gif) |
DELRIEUPierre Psycho Posteur
Posté le: 20/07/2010 02:17 Sujet du message: |
Normal that you make as great , with as beautiful vegetables in the garden
good work
Pierre |
Posté le: 20/07/2010 07:56 Sujet du message: |
« Hecquetmarc » a écrit: Nice work but why so many spars on the inner wing? ![[humm]](images/smiles/humm.gif) (according to the scale appearance?)
You are right, that's not entirely scale design . But with wing root at 52cm I was a bit worried about mechanical aspect. As the front side will be planked only the two spars will be visible. Still one too much , but I just wanted to be on the safe side ...
« DELRIEUPierre » a écrit: Normal that you make as great , with as beautiful vegetables in the garden
good work
That's one of my wife's contributions to this project ... |
Posté le: 20/07/2010 08:20 Sujet du message: |
I understand your fear , I suppose you put a cap on the ribs so the spar will not appear directly after the wing is covered nevertheless there is no problem if you build a strong trailing edge.Do you install airbrakes on upper and bottom sides of the wing? |
Posté le: 20/07/2010 13:47 Sujet du message: Minimoa ! |
Not sure about the airbrakes yet ... It would be much easier to make them just on the upper side. On the other side, two sided airbrakes, like the one I made on my Kranich, add that something to real front figure when you are aproaching for landing ... |
Posté le: 20/07/2010 16:20 Sujet du message: |
If you're not involved in a true scale sailplane, make the simpliest way...  |
Posté le: 02/11/2010 11:19 Sujet du message: Minimoa ! |
Quite some progress was made in past few weeks ... This is the current state of the project...
Regards !
Uroš |
Posté le: 02/11/2010 12:02 Sujet du message: |
Hallo Uroš,
Sieht einfach toll aus, deine MiMo
Schade das das Holzwerk wieder verdeckt wird
Gruß Johannes |
Posté le: 02/11/2010 12:34 Sujet du message: |
« Johannes » a écrit: Hallo Uroš,
Dieses mal nicht ... Wird mit oratex natur gespannt ...
Uroš |
Orionis Incurable Posteur
Posté le: 02/11/2010 13:35 Sujet du message: |
Hi, Uros, nice building!
It's a good thing you've built its own shelter!
 Fabrice |
Walter L. Maniaco Posteur
Posté le: 02/11/2010 21:51 Sujet du message: |
Hello Uroš,
your glider is really great!
Which profile do you use?
Do you have an idea which weight the modell will have?
Best regards
Walter |
Posté le: 02/11/2010 22:42 Sujet du message: |
Great job, no doubt I will also build a big Minimoa one day after the one I made a few years ago at 1:3,5 scale, even if it's a great classic often built...Maybe the two seater... Which scheme did you choose for yours?
![[clap]](images/smiles/Clap.gif) |
Posté le: 03/11/2010 08:53 Sujet du message: |
« Walter L. » a écrit: Hello Uroš,
Best regards
I used HQ 3.5/14 on the middle section and HQ 3.5/12 on the outside. Regarding weight, it sould be under 20kg, I guess around 17kg.
« Hecquetmarc » a écrit: Great job, no doubt I will also build a big Minimoa one day after the one I made a few years ago at 1:3,5 scale, even if it's a great classic often built...Maybe the two seater... Which scheme did you choose for yours?
It will be HB-232 design. Covered with natur oratex and painted white.
Regards !
Uroš |
Posté le: 03/11/2010 12:17 Sujet du message: |
Good job Uros
I use the same profile on my new C 25, normaly it's efficient and not too speed
