My Doppi
1, 2, 3, 4 Suivante
czirh
Âge: 62 Sagittaire
MessagePosté le: 23/03/2009 17:54    Sujet du message: Répondre en citant
Left wing & aileron..
czirh
Âge: 62 Sagittaire
MessagePosté le: 23/03/2009 17:59    Sujet du message: Répondre en citant
When I finish the model, I shall try it on the slope (I have no other alternative).
(a) Model set-ups for slope soaring?
(b) The down-up movement of aileron, elevator, rudder in cm?
(c) Any additional hints on the slope soaring for this model?
(d) Any additional reinforcement on the fuselage and wings before covering?
I shall be grateful if any of you have answers to my questions!
Thank you all in advance Very Happy
Cem
MessagePosté le: 23/03/2009 19:13    Sujet du message: Répondre en citant
Hi Cem
if you can, use 2 setup with your dual rate for aileron and elevator
elevator:
small: +10mm (down) / -15mm (up)
large: +15mm (down) / -20mm (up)
ailerons:
small: +10mm (down) / -18mm (up)
large: +15mm (down) / -25mm (up)
rudder: maximum... 40/45° or 50/60mm
but these valors are not critical, Doppy is not a vicious glider [arf]
czirh
Âge: 62 Sagittaire
MessagePosté le: 23/03/2009 20:45    Sujet du message: Répondre en citant
Thank you very much , Vincent .. [good]
czirh
Âge: 62 Sagittaire
MessagePosté le: 26/03/2009 19:56    Sujet du message: Répondre en citant
Right aileron.. 24
czirh
Âge: 62 Sagittaire
MessagePosté le: 28/03/2009 08:01    Sujet du message: Répondre en citant
Second video: 28
Tow release system..
http://vimeo.com/3884231?pg=embed&sec=
I have used standard servo. Right? Or should I use a more powerful servo?
MessagePosté le: 28/03/2009 08:56    Sujet du message: Répondre en citant
you can used standart servo but the gra....er 5077 is good for this job Wink
czirh
Âge: 62 Sagittaire
MessagePosté le: 28/03/2009 14:46    Sujet du message: Répondre en citant
Okey , thank you very much.
I have used Futaba S3004.
czirh
Âge: 62 Sagittaire
MessagePosté le: 28/03/2009 15:17    Sujet du message: Répondre en citant
Canopy..:
czirh
Âge: 62 Sagittaire
MessagePosté le: 29/03/2009 17:18    Sujet du message: Répondre en citant
After painting canopy frame.
Benoit1664
Âge: 65 Scorpion
MessagePosté le: 30/03/2009 05:42    Sujet du message: Répondre en citant
brilliant, is your canopy.......
( dixit ma Môman...)
czirh
Âge: 62 Sagittaire
MessagePosté le: 30/03/2009 17:57    Sujet du message: Répondre en citant
New canopy pictures..
MessagePosté le: 30/03/2009 18:00    Sujet du message: Répondre en citant
very good [good]
now, the more difficult is finish
czirh
Âge: 62 Sagittaire
MessagePosté le: 30/03/2009 19:44    Sujet du message: Répondre en citant
very good [good]
Thank you , Vincent. Very Happy
For me the most difficult is the pilot figüre. [argh]
Cem
czirh
Âge: 62 Sagittaire
Nouveau messagePosté le: 31/03/2009 19:29    Sujet du message: Répondre en citant
I have started covering.. Rolling Eyes
czirh
Âge: 62 Sagittaire
Nouveau messagePosté le: 01/04/2009 16:58    Sujet du message: Répondre en citant
Tail pictures..:
Cem Zırh
Fafnir
czirh
Âge: 62 Sagittaire
Nouveau messagePosté le: 02/04/2009 15:02    Sujet du message: Répondre en citant
Fuselage pictures. 24
Cem Zırh
Fafnir
czirh
Âge: 62 Sagittaire
Nouveau messagePosté le: 02/04/2009 15:08    Sujet du message: Répondre en citant
More fuselage pictures....
Cem Zırh
Fafnir
Nouveau messagePosté le: 02/04/2009 15:15    Sujet du message: Répondre en citant
Cem, what color scheme you have choised? white and orange like PH-814 ? > http://www.retroplane.net/angouleme/accueil.htm
czirh
Âge: 62 Sagittaire
Nouveau messagePosté le: 02/04/2009 19:57    Sujet du message: Répondre en citant
I plan to make it simple. Main colour white, text gray [good]
Cem Zırh
Fafnir
czirh
Âge: 62 Sagittaire
Nouveau messagePosté le: 04/04/2009 15:09    Sujet du message: Répondre en citant
Wings covering.. 24
Cem Zırh
Fafnir
czirh
Âge: 62 Sagittaire
Nouveau messagePosté le: 05/04/2009 17:52    Sujet du message: Répondre en citant
White Doppi.. 24
Cem Zırh
Fafnir
czirh
Âge: 62 Sagittaire
Nouveau messagePosté le: 05/04/2009 19:10    Sujet du message: Répondre en citant
To balance the CG, I will have to use a lot of weight (lead). May be I should use a led pilot Laughing
Cem Zırh
Fafnir
Nouveau messagePosté le: 06/04/2009 05:47    Sujet du message: Répondre en citant
And you started the build 1 month ago Shocked
on mine, I used 200g of lead + a battery 220g
czirh
Âge: 62 Sagittaire
Nouveau messagePosté le: 08/04/2009 16:12    Sujet du message: Répondre en citant
My Doppi ... VOILA !!!
Cem Zırh
Fafnir
Nouveau messagePosté le: 08/04/2009 16:30    Sujet du message: Répondre en citant
very nice [clap]
Nouveau messagePosté le: 08/04/2009 16:38    Sujet du message: Répondre en citant
[clap] [clap] , beautiful and more speed that your schade
Nouveau messagePosté le: 08/04/2009 17:57    Sujet du message: Répondre en citant
Too much quik, unbelivable Rolling Eyes ..... But very nice
Congratulation [clap]
czirh
Âge: 62 Sagittaire
Nouveau messagePosté le: 09/04/2009 20:40    Sujet du message: Répondre en citant
Thank you all.. Very Happy
Cem Zırh
Fafnir
Nouveau messagePosté le: 13/04/2009 07:10    Sujet du message: Répondre en citant
Hi Cem, very nice, and original with Turkish flag Very Happy
soon the first flight? make a serious check-list and wait the best wind Wink
1, 2, 3, 4 Suivante
Page 2 sur 4
