bocorvin Accro Posteur
Posté le: 21/02/2021 11:58 Sujet du message: |
Bonjour a tous,
Now I could cover the bottom of the fuselage. I came up with a sanding tool so I could clamp the panels, otherwise my fingers would get cramped
 A batten attached to my worktop with a screw clamp , a piece of aluminum angle and two large spring clamps. The sanding went a bit better now
 Fuselage and panel with glue , panel in position and secured with a hot iron.
 After a few days it starts to become a fuselage
 Next is the nose, lots of small panels and that will take some time....
Vincent (DB) |
Sed Accro Posteur
Posté le: 21/02/2021 19:32 Sujet du message: |
Hi Vincent,
Very great job as usual !
A little question : have you use 0.6mm plywood for the complete fuselage ? And for the nose ?
Good evening.
 Serge |
Posté le: 21/02/2021 21:12 Sujet du message: |
Hi Sed,
Thanks for yout nice words .
Yes I am using 0.6 mm ply for the fuselage. I will cover the nose cone (pif?) with 0.6 mm veneer (thin, massive wood) so I can sand it without showing the dark glue.
Vincent(DB) |
ManfredNeu Accro Posteur
Posté le: 22/02/2021 10:31 Sujet du message: |
Hallo Vincent,
sehr saubere Arbeit und das mit der Schleifhilfe ist eine gute Idee. Danke . Das werde ich auch ausprobieren.
Manfred |
texier Accro Posteur
Posté le: 22/02/2021 20:36 Sujet du message: |
Hello Vincent,
Your work on the panels is top It is really valuable to spend time on building tools when we see the accurate result !
 Sylvain.
Hibernatus Fidèle Posteur
Posté le: 23/02/2021 09:24 Sujet du message: |
Salut
Belle réalisation pour ces coffrages.
@+Christian
 Bon sur ce je retourne coller mes morceaux de bois. |
Clifton Psycho Posteur
Posté le: 23/02/2021 13:32 Sujet du message: |
Comme d'habitude, de beaux modèles et une belle construction. Bravo !
Posté le: 24/02/2021 20:31 Sujet du message: |
Thanks for your nice comments,
Vincent (DB) |
