Slingsby Gull scale 1/4
bocorvin
Âge: 73 Vierge
MessagePosté le: 08/01/2020 18:07    Sujet du message: Répondre en citant
Hello everyone,
A friend had some doubts of the reinforcements I had made me at a weak point, which I had created in by drilling in the lower mainspar. I had a bit of a blind spot [non]. Glad he told me that, it was easy to improve now Very Happy So I took out the webbing plate, cleaned up the spar and chamfered the extra layers.
made also doubler on the top spar and put a double webplate at the front of the spar.
I couldn't put extra wood at the rear of the spar, (it was not on the real thing) so instead of that I put on some glasrovings with epoxy on the webbing plate. Later I laminated some short sections of glastape on the webbing to reinforce that also.
Its looking better, so I could go on with all kind of details of the wings.
To be continued,
Vincent.
Mad Doc
Âge: 43 Scorpion
MessagePosté le: 12/01/2020 19:55    Sujet du message: Répondre en citant
How nice it is to watch you working!!!
I definetely have to learn to do some of that soldering!
bocorvin
Âge: 73 Vierge
MessagePosté le: 23/01/2020 13:18    Sujet du message: Répondre en citant
Hello everyone,
Thanks Cristian for your nice comments! The silversoldering is not that difficult, reading a bit, the right stuff and a lot of try and error (sometimes burnt fingers [non] )
Next was with the nose of the wing.
I was a bit worried about that, there are about 12 joints in the ply covering of each wing (there is a bend in it; 4 seams). Scarf joints is very difficult to do it properly because of all curved surfaces. I build fuselages with butt plates instead, wich worked OK. In the wing it would be easier solved with thin glass/epoxy, instead of much thicker ply.
On a flat, (non sticking) surface I soaked 25mm glasstape with epoxy and let it cure. I took that off and cut it in the middle, getting strips of 12mm wide, 0.2mm thick and very flexible. I glued that with cyano an the ribs were the joint was needed. Sanded the rib first slightly down a bit (just the 0.2mm).
The panels were prebended, using boiling water and dried for some time. I fitted both sides and left a overlap at the main spar. Glued it with thick cyano on the leading edge, put the panel on, fold it in its correct position and let that harden
The wing is held vertically just for easier gluing
Now I put the wing flat, opened up one side, put glue in it and closed it while pulling it back.
Turned the wing over and glued the other side. Cut of the surplus
After a lot of gluing..
Still a lot of fiddley things on the wings to do.
To be continued,
Vincent
Olli
Âge: 52 Verseau
MessagePosté le: 23/01/2020 14:19    Sujet du message: Répondre en citant
Hi Vincent,
nice wood work [clap] [clap] Very Happy Very Happy
Best Regards Olli
Âge: 60 Bélier
MessagePosté le: 23/01/2020 20:24    Sujet du message: Répondre en citant
Nice work ! One more devotee for skin laying with thick cyanoacrylat glue.
bocorvin
Âge: 73 Vierge
MessagePosté le: 23/01/2020 23:39    Sujet du message: Répondre en citant
Hi Olli and Eric
Thanks for your nice remarks Olli Very Happy Very Happy !
About the cyano Eric, thats because of the building story of your Nemere [clap] [clap] .
Besides, it appeared to be quite strong, see "atelier reparation, Nemere 1/6"
Vincent.
Âge: 62 Cancer
MessagePosté le: 24/01/2020 18:04    Sujet du message: Répondre en citant
Nice work Vince [clap] [clap]
bocorvin
Âge: 73 Vierge
MessagePosté le: 29/01/2020 22:00    Sujet du message: Répondre en citant
Thanks a lot for your remarks Pat' Very Happy .
I went on with all the control wires, first the wing, I changed the wires for a bit thinner wire, 20 KG, about 0.53mm thick. It was 30KG and that was a bit stiffer and the pulleys are not that big, now its working better.
From 1mm steel wire I bended a loop, which locks the aileron and which I (hope) to unlock via the slot for the control wire .
Th pull-pull wires for the elevator attached at the bellcranck
and also the wires for the rudder with a kind of homemade kwiklinks
Now it was time to put the lower ply panels on the fuselage, first I glued on the strips which acts as butt-plate
sanded everything and started to glue the panels
prepared, put on the thick cyano
put it in position and pressing it with a batten of 10X10 with non adhering tape on it (the brown parcel stuff)
there are some more panels to do...
The wings are now 975gr, servo's included and some minor panels missing.
Vincent
Âge: 56 Scorpion
MessagePosté le: 29/01/2020 23:28    Sujet du message: Répondre en citant
Hello Vincent,
you should put on gloves to stick with the cyano… it's safer for your fingers !
Good luck for the future ; it looks good Very Happy
Pourvu que ça vole, roule, flotte… normalement j'ai tout bien fait pour !
Âge: 48 Gémeau
MessagePosté le: 29/01/2020 23:33    Sujet du message: Répondre en citant
Hi Vincent,
Congratulations, it's superb [clap] [clap] [clap]
Friencly,
bocorvin
Âge: 73 Vierge
MessagePosté le: 30/01/2020 14:19    Sujet du message: Répondre en citant
Merci Sebastian et Lolo, and I'll put my gloves on Cool.
Vincent.
Âge: 57 Capricorne
MessagePosté le: 04/02/2020 23:08    Sujet du message: Répondre en citant
Hi Vincent,
I'm coming back to the forum after a long time.
Very nice build, I love this sailplane. I hope I'll see your Gull flying one day.
Friendly,
bocorvin
Âge: 73 Vierge
MessagePosté le: 05/02/2020 10:46    Sujet du message: Répondre en citant
Hi Philippe,
Nice to hear from you again Very Happy. Thanks so much for your comments.
The planning is to fly the Gull at retroplane 2020, hopefully you see it there. It can fly as a "strutted" Gull and also as a "cantilever" Gull or Gull III.
Friendly,
Vincent
bocorvin
Âge: 73 Vierge
MessagePosté le: 06/02/2020 12:37    Sujet du message: Répondre en citant
Hello everyone,
Next was the fuselage, a lot of panels!
The doublers low in the fuselage are to reinforce the fuselage were you hold it to hand launch it.
and a look at the inside with the steering cables in place
I also put some weight between the side panels in the front.
and it began to look a bit like the Gull Very Happy
Now the nose (pif? Very Happy)
and the real thing
this was presumably the prototype, it has the short canopy. what I liked was the difference in tints. So I choosed to put different veneers in the nose. Hopefully it will tone down after the staining, I will see.
I use veneer (massive thin wood) instead of ply, its possible to sand it.
and sanded
To be continued,
Vincent
Sed
Âge: 54 Taureau
MessagePosté le: 06/02/2020 12:57    Sujet du message: Répondre en citant
Superbe, comme d'habitude [clap] [clap] !
Page 6 sur 12
