RobertoP Fidèle Posteur
Posté le: 03/12/2011 22:18 Sujet du message: CVV - 4 Pellicano |
Hi All,
after having concluded my Bocian, I start the design of a new glider, the CVV 4 Pellicano an Italian 15m sailplane. I decide for ¼ scale, my design follow the construction method used by Vincent for MG9, I would like to try all plywood construction. Now I have concluded the drawing of fuselage, and also the project of the wing is quite at the end. Here my fuselage project and some photo of full scale glider.
Roberto
Posté le: 04/12/2011 07:09 Sujet du message: |
Hi Roberto, it's a nice winter's project
caralp_laurent Psycho Posteur
Posté le: 04/12/2011 22:19 Sujet du message: |
Hi Roberto,
yes, it's a magnificent glider, i like it very much
Good luck for building it
Sénèque |
ValerioA Apprenti Posteur
Posté le: 05/12/2011 11:09 Sujet du message: |
Ciao Roberto,
ma per avere notizie sul Pellicano devo consultare Retroplane????
Valerio |
Posté le: 05/12/2011 19:54 Sujet du message: |
Posté le: 05/12/2011 23:03 Sujet du message: |
Rather similar to the Minimoa nice project |
Posté le: 08/01/2012 00:31 Sujet du message: |
Hi All
I have concluded the drawing of the wings now I need to start with the cutting of various pieces and start the construction
Roberto
Posté le: 25/03/2012 22:59 Sujet du message: |
Hi All,
the construction of my Pellicano is started, first I make an order to easy CNC for cuttings the ribs, than I cut the various pieces of fuselage and start the work for the stabilizer that now is concluded. The next step is the fuselage.
Roberto
Posté le: 26/03/2012 07:10 Sujet du message: |
Nice work for the stabilizer ![[clap]](images/smiles/Clap.gif)
Posté le: 01/04/2012 18:49 Sujet du message: |
Hi All,
Today I start with the construction of fuselage with the first dry test
Roberto
Posté le: 15/04/2012 20:46 Sujet du message: |
Hi,
The structure of fuselage is quite finish now I have to start with cockpit and the control system of horizontal tail and then the covering with plywood.
The photo on the book is the photo of full scale Pellicano on construction.
Roberto
Posté le: 15/04/2012 21:14 Sujet du message: |
Posté le: 30/04/2012 20:48 Sujet du message: |
Thanks Christian,
the work on Pellicano is proceeding slowly,now I start with the sheeting of fuselage here enclosed some photos.
Roberto
Posté le: 01/05/2012 05:53 Sujet du message: |
Hi Roberto, great work plywood is really the best
Posté le: 02/05/2012 09:28 Sujet du message: |
Bravo Roberto, super work!
valerio |
Posté le: 06/05/2012 21:21 Sujet du message: |
Hi All,
Following the sheeting of the full scale Pellicano the covering of fuselage is proceeding
Roberto
Roberto
Posté le: 07/05/2012 23:16 Sujet du message: |
Hi,
other photos
roberto
Posté le: 23/09/2012 18:17 Sujet du message: |
Hi All,
Some photos of fuselage of my Pellicano covered, with plywood.
Roberto
Posté le: 23/09/2012 18:53 Sujet du message: |
Hi Roberto,
Very beautiful work on the plywood ![[clap]](images/smiles/Clap.gif)
Posté le: 30/09/2012 21:08 Sujet du message: |
Hi Vincent,
thanks, but unfortunately my work is not so good as your work on your Musger MG9, you are so precise in the junction of various plywood panels and I really I do not understand how you can do this perfect junction.
Here enclosed other two photos of my Pellicano
Roberto
Posté le: 01/10/2012 06:08 Sujet du message: |
No problem, that's realistic like this, full size had same look
Posté le: 02/10/2012 10:06 Sujet du message: |
very Nice work Roberto, you can obtain better junctions of the panels with cutting templates prior to the cutting of the panels themselves to fit them perfectly but not too much ( it's a long work but no waste of plywood and more precise work) .
Avoid to sand too much the junction of the panels. It is worth bevelling carefully the panels and then you can determine the gap between them and there's almost no need to sand .
Posté le: 20/10/2012 20:59 Sujet du message: |
Hi All ,
Now I have concluded the covering of fuselage of my Pellicano and now I am working on karman here enclose some photos
Roberto
Posté le: 21/10/2012 09:42 Sujet du message: |
Christian |
Hibernatus Fidèle Posteur
Posté le: 27/10/2012 23:40 Sujet du message: |
Jolie construction
Les plans de joints sont très réalistes
@++ Christian
Posté le: 28/10/2012 19:42 Sujet du message: |
Hi All,
many thanks to all for the compliments, today I have concluded the covering of fuselage now I have to start with the moving part of rudder and then the wings .
Roberto
Posté le: 01/01/2013 17:38 Sujet du message: |
Hi All ,
I would like to wish to all peoples of the forum an happy new 2013, speaking about my Pellicano I have concluded the rudder and I start with the wings here some photos
Roberto
Posté le: 13/01/2013 21:51 Sujet du message: |
Hi All,
other pictures of my Pellicano,
Roberto
Posté le: 14/01/2013 09:46 Sujet du message: |
Salut Roberto !
Posté le: 14/01/2013 11:58 Sujet du message: |
Very nice building Roberto...Happy new year to you and your family.
" Ah, ces ailes en mouette.."
" Ah, these gull winged sailplanes.. ( famous sentence on Retroplane forum )  |
