sebastian92 Psycho Posteur
Posté le: 18/09/2019 21:16 Sujet du message: |
nice job, very technical ! i like it
bocorvin Maniaco Posteur
Posté le: 12/10/2019 09:54 Sujet du message: |
Bonjour a tous,
I went on with the ribs, finally the very thin battens (1 X 1mm) had arrived and I drawed the pattern for them on the ribs with pencil
 The battens are cut off after glueing with a small wire cutter, and sanded.
Now I could built the wing itself
 I like the curve in the wing!
to be continued,
Vincent |
Posté le: 26/10/2019 12:07 Sujet du message: |
Bonjour a tous,
After gluing in all the battens and vertical webs I went on with the hinges. I used the method of Vincent Besancon (sorry I don't have the French correction ) and I pre cut the ribs
 so I could glue the hinges in place before cutting of the aileron. Next I tried to figure out the pulleys of the pull pull wires
 and getting the angles correct. The rudderhorns on the aileron have the same throw as the on the servo. I had to create a lot of space for the wires in the ribs at the root, even I had to reinforce one rib.
 planning the pull pull wires
 The actuation of the spoiler came quite close to the pull pull wires of the ailerons.
 The servo arm is in its most extended position when the spoiler is closed, so there is less chance of burning the servo....
Laminated tip
 and the trailing edge is built up of 0.8 mm ply bottom and top, balsa in between. I laminated the balsa also in the curve of the trailing edge
 I guess there is less figuring out with the other wing
Vincent |
Sed Accro Posteur
Posté le: 26/10/2019 15:26 Sujet du message: |
Perfect job as usual !
Olli Incurable Posteur
Posté le: 26/10/2019 23:33 Sujet du message: |
Thanks Sed and Olli for your nice commets !
Vincent |
Mad Doc Fidèle Posteur
Posté le: 31/10/2019 16:30 Sujet du message: |
Hello Vincent!!!
What a beautiful model, and what a nice work!
I´m sure it will look just nice in the air!
Greetings,
Christian |
Posté le: 01/11/2019 13:32 Sujet du message: |
Hello Chtistian, thanks for your nice comment .
In the meantime I went on with the other wing and that went indeed a lot faster! So yesterday I put it all together in the sunshine, its now raining First in the attic (It just fits)
And outside
To be continued,
Vincent.
Posté le: 01/11/2019 13:38 Sujet du message: |
Prachtig! Een echte kunstwerk.
![[amen]](images/smiles/amen.gif) |
caralp_laurent Incurable Posteur
Posté le: 01/11/2019 14:30 Sujet du message: |
Wow, magnificent job Vincent !!!
Friendly
Posté le: 01/11/2019 15:31 Sujet du message: |
Merci Harold et Lolo,
Thanks for your nice comments!
Hopefully it will fly nice, Each wing is 650gr at this moment
To be continued,
Vincent |
jean-jacques stannard Fidèle Posteur
Posté le: 01/11/2019 16:19 Sujet du message: slingsby gull |
Dreaming build !!!! ![[clap]](images/smiles/Clap.gif) |
Johannes Psycho Posteur
Posté le: 01/11/2019 20:46 Sujet du message: |
Hallo Vincent,
Die Holzkonstruktion sieht wunderschön aus
viel zu schade diese unter einem Gewebe zu verstecken
Liebe Grüße
Posté le: 01/11/2019 21:26 Sujet du message: |
Thanks all for the encouraging comments
First I have to finish the construction of the wings, then all the pull-pull wires for the controls, than the canopy mold and then all the bits of ply. It will take some time!
Die rumpf ist vollig beplankt, die Flugel nur die nase, hier noch ein photo von das vorbild.
Vincent |
