Posté le: 10/04/2017 09:37 Sujet du message: |
Congratulations Vincent , the behaviour of the Fokker
FG2 seems quite good now! Nice video movie
ThomasF Incurable Posteur
Posté le: 10/04/2017 09:56 Sujet du message: |
Klasse!! |
Posté le: 10/04/2017 10:14 Sujet du message: |
BRAVO
Posté le: 10/04/2017 10:30 Sujet du message: |
Congratulations.
Beautiful flights. Very impressive.
Nice weather conditions. Good friends to help you. Also a very good pilot for the drone.
Best regards.
Harold |
Philippe26 Psycho Posteur
Posté le: 10/04/2017 10:42 Sujet du message: |
Hi,
Very good report of these first flights, photos, films from various angles.
Great plane, great flights,
GOOD JOB !
All the best for the futur.
Posté le: 10/04/2017 13:25 Sujet du message: |
Congratulations
Very nice in flight
Posté le: 10/04/2017 17:19 Sujet du message: |
magnifique look in flight !
and very nice video ! you are equipped so !
Fotor Stagiaire Posteur
Posté le: 10/04/2017 17:44 Sujet du message: |
Bravo Vincent, superbe vol, belle vidéo
Ce n'est pas évident votre piste, atterrissage de l'autre côté du canal, faut pas aller dans l'eau
On a hâte de le voir évoluer à hauteur des yeux cet été à Vauville surtout ne l'abîme pas avant Retroplane!
Posté le: 10/04/2017 18:01 Sujet du message: |
Vincent, les photos, la vidéo ,un régal
bocorvin Maniaco Posteur
Posté le: 10/04/2017 19:16 Sujet du message: |
Merci a tous pour les comments!
To start; the FG-2 had a lot of things unknown to me, so I am very glad it worked out well!!
About the canal; this flight terrain is an former military airfield, which is now demolished. Sometimes ditches and small humps appear, but we are very glad to have a place to fly in this crowded piece of the world!!
Yesterday we had all things together; the tow plane, the photographer and good weather, only the wind came from an unusual direction. This stretch of tarmac was the only place for take off, and the other side of the canal was grass and the only place to land without damage.
Surely I try not to damage it before Vauville!!
Now I can do the finishing touches!
Vincent
Absolutely marvelous Congratulations. So beautiful is it ! And the video very nice too !
Sed Maniaco Posteur
Posté le: 10/04/2017 20:51 Sujet du message: |
Vraiment superbe Vincent (le modèle, la construction, le vol, les images,...) !
Je suis très heureux pour toi de cette réussite après les petits soucis des premiers essais .
Mais si je comprends bien, tu es passé directement du lancer-main au remorquage !?
Je te souhaite plein de beaux vols à Vauville .
Posté le: 10/04/2017 23:33 Sujet du message: |
Merci Phillippe et Sed pour les comments!
Yes I went directly from handlaunch to towing. I have very little experience with "le sandow", thats why.
On the pictures is the nice transfer from Adri and Rob, this is how it looks;
I don't think a lot of people recognise it
Vincent |
Posté le: 16/04/2017 16:00 Sujet du message: |
Entschuldige Vincent das ich mich erst heute melde:
Dein erster F-Schlepp ist super geworden :
Herzlichen Glückwunsch
Weiterhin tolle Flüge mit schönen weichen Landungen
Liebe Grüße Johannes |
Posté le: 16/04/2017 20:16 Sujet du message: |
belle machine
Signé les copains |
Posté le: 17/04/2017 11:17 Sujet du message: |
Danke Johannes, ja ich war ganz erleichtert das der FG gut geflogen hat
et merci Pierre, le FG c'est certainement une machine!
Je continue en Anglais,
To start with, it was an relief and at the same time very rewarding to see th FG flying, she is so translucent, a bit archaic, we enjoyed it very, very much!!
After these first flights it was obvious that the cg was too for forward. Somewhere the fact was in my mind that the main girder was on 30% and I put the cg there. Later I discovered that the girder was on 25%, so I had to take out some lead. I figured out that about 220 grams less was sufficient.
No easy acces, the camera is much smaller than my head!
Two holes in the diacov to take the bolts out
Some wrenching because the lead was glued with epoxy
and with tweezers put the nuts back
Th cg was now at 30%, hopefully that is right, at least I know how to get out more!
There was another thing that worried me, the wiring or rigging of the wing warping. I made a sketch to clarify things
as you can see there are two ( I came up with the names, maybe ther are better names for those wires) "control wires" ataching the servo arm with the upper wings, and one "connecting wire" between the lower wings via a pulley inthe center just under the upper wing. If there is a failure of one of the control wires, the plane is uncontrolable, its only possible to roll to one side and not back. That was a worrying thought! When testing stationary sometimes the quicklink on the servo arm snapped out and after the handlaunches there also unsnapped other quicklinks. I didn't trust the quicklinks 100%. There are other quicklinks with locking plates
(top on the picture) put the locking plates are so tiny, they will get lost, I am afraid. I made a spring of 0.6 steel wire, around a 4mm drill and snipped off pieces of a couple of windings, which you can slide over the quicklink (bottom) It looks reassuring, hopefully they do there job.
I could not use this on the servo arm, because of the full throw I need there. I modified the quicklinks into more permanent linking
The bushes are long enough to give free rotation when the M 2 nuts are fastened. The metal strips are ment to give a better load distribution on the plastic of the servo arm.
I use these locking rings on some important quicklinks of the other rigging, so I get a bit more trust in all those wires!
One advantage of the wiring and floppy wings is the following thing; by adjusting (shorter) the "connecting wire"it is possible to introduce a smaller angle of incidence at the tip, to get better stall charasterics.
To be continued,
Vincent. |
Mad Doc Accro Posteur
Posté le: 20/04/2017 13:48 Sujet du message: |
Ich hab auch lange nicht reingeschaut, staune um so mehr!! Toll! Super Erstflug-Video!!!!
Holland ist natürlich ein sehr toller Ort um zu schleppen, Ihr habt dort so viel Platz und gerade Flächen... und nebenan direkt eine Wasserflug-Startbahn...
Herrlich!
Liebe grüße,
Christian |
Posté le: 20/04/2017 16:20 Sujet du message: |
Hallo Christian,
Ja, die Erstflug war schon!! Doch immer ein bisschen "No guts no glory".
Ich hatte immer geglaubt das in Deutchland mehr Platz um zu fliegen wahre, im Holland ist das sehr schwierig irgendwo platz zu finden, so wir sind ganz froh mit diese Stelle. In eine woche hatten sie die Graben gemacht und dan gab es Wasser! Und mit Wasser ist das genau dasselbe wie mit Baume, die Modellen ziehen dahin .
Liebe grüße,
Vincent |
Posté le: 23/04/2017 22:43 Sujet du message: |
Un grand bravo ! Il est superbe ton biplan, la silhouette et la transparence waouwww, magnifique !
Posté le: 24/04/2017 14:44 Sujet du message: |
Salut Lolo,
Merci beaucoup !
I am also very pleased with the transparancy of the wings, the 140+ "nervures aux baquettes" had their effect!
Vincent |
Posté le: 07/05/2017 19:50 Sujet du message: |
Bonjour a tous,
I did some small things, to make the quicklinks less visible I blackened them chemically with Bernax 540 of which I happened to have some.
rinsed them with water.
Then I discovered a problem; on which spot could someone hold the plane when the catapult (sandow) was under tension?
I think the rudders are to weak, the attachment for the horizontal stabilizer is also a bit weak, besides there is no room for one hand. Rigging wires all over the place!
So I made a device, or better said a contraption to hold the glider in place with the catapult under tension, with a release hook.
I used a modified standard release hook connected with a 8mm stainless steel tube attached to a wooden handlebar. A 1mm stainless steel operating wire with a rope loop as a trigger.
On the plane I made also a demountable loop, attached to 0.6 mm steel wire, which was connected to one of the wing struts.
Here Sjoerd demonstrates how it should work (I tested it at home with 15 KG tension and the plane stayed horizontal too)
Today Rob towed the FG 2 again and it performed well.
The CG looks OK, the elevator is just a degree or 2 up, the plane was really flying!
Vincent
Posté le: 07/05/2017 20:26 Sujet du message: |
Hi Vincent,
spitze wie Du solche Probleme löst -
super Idee
LG Johannes |
Posté le: 07/05/2017 20:27 Sujet du message: |
hello Vincent,
Very interesting your system of trigger of dropping for the plane difficult to block on hands… !!
Posté le: 07/05/2017 22:54 Sujet du message: |
Hello Johannes und Sebastian,
Thanks! Hopefully this thing works properly at Vauville!
Vincent |
fabplane56 Stagiaire Posteur
Posté le: 04/07/2017 14:42 Sujet du message: |
beautifull model , and the work on it is simply awesome ! i wish i had the skill to make a such model stickers voiture
Posté le: 04/07/2017 17:07 Sujet du message: |
Thanks a lot for your comment!
About the skills, its mostly a matter of practice...
Vincent |
Posté le: 30/07/2017 00:04 Sujet du message: |
Je ne me lasse pas de regarder ta vidéo , merci pour les images elles trouveront leur place sur la vidéo
Quel bonheur d'avoir vu voler plusieurs fois ce Fokker sur une des plus belle pente de France ,
Posté le: 30/07/2017 09:27 Sujet du message: |
alors la un très grand bravo c'est du grand art
