Posté le: 28/03/2017 06:37 Sujet du message: |
Wonderfull work.
Mad Doc Accro Posteur
Posté le: 28/03/2017 08:56 Sujet du message: |
Wow!!! Mehr Bilder!!!
Grüße,
Christian |
bocorvin Maniaco Posteur
Posté le: 28/03/2017 11:01 Sujet du message: |
Thanks Pat, Christian and Raymond!
We had an eventful day, yesterday! After a long period of dull weather we had sun, so it was an excellent opportunity to do a fotoshoot. Raymond knew a nice location, so we started;
The building up takes a lot of time, I am thinking of improving that...
Wires all over the place....
And securing pins..
All those ribs...
Last wing slides on its place..
It had the nice transparancy where I was looking for
It was difficult to hold it!
Finally completed!
Because it was nice weather we decided to make some hand tosses.
Some problems became apparent.
First its difficult to get an hold on the fuselage?? so it was difficult to toss.
This is a link to a video of the bulding up and first tosses.
https://www.youtube.com/watch?v=nnVJrVO_WWs
As you can see, it needed some improvement!
The rigging appeared to be to weak, a lot of wire was not good clamped
The strain on the wires is pretty high with the kind of "landings" I made .
I also have some doubts about the wing warping, I am lokking to improve that.
Ther was also some damage at the wooden parts, a bit on the root of the wing and the skid.
I'll make the next changes; replace the rigging with heavier wire (90 kg) and improve the clamping, also securing the clevices and testing if it is strong enough.
Looking if it is possible to enhance the warping. I have some doubts about the control off the rolling, horizontal tailplane gives ample control!
Repair the skid and wing. When that is OK the FG can be towed, it is good that this weak points of the plane are discovered with little damage.
Thanks Raymond for the mental support!
To be continued,
Vincent |
Posté le: 28/03/2017 12:12 Sujet du message: |
Hooo, Vincent, you are crazy to do hand launch with this model at the field not enough speed to have good reactions, use a bungee or go to the slope or towing, please stop hand launch before destroy it
Posté le: 28/03/2017 12:20 Sujet du message: |
Hi Vincent,
Yes, I am going to tow!! it and yes I am a bit crazy . Luckily the model appeared to be quite strong
We don't have something like a slope but you are right, no hand launches. (with the Nemere it went OK, that's why we tried it)
Thanks Vincent, I'll listen to you
Vincent |
Posté le: 28/03/2017 12:54 Sujet du message: |
Yes, marvelous !
keep cool, you have time to secure all
Posté le: 28/03/2017 18:08 Sujet du message: |
le lancer à la main comme ça sans vitesse quel risque dommage!
Tu as de la chance Vincent il n'y ait pas trop de bobos.
Sed Maniaco Posteur
Posté le: 28/03/2017 19:46 Sujet du message: |
Bonsoir Vincent.
Ton Fokker est vraiment splendide et je suis soulagé de voir qu'il n'a pas subi de dégâts trop importants !
Je m'excuse par avance si je "pollue" un peu ton post, mais cette petite mésaventure m'inquiète quelque peu car à dire vrai, je pensais procéder un peu de la même façon le moment venu pour faire voler le Tenax... Et au vu des différentes réactions des pilotes expérimentés du forum, cela ne semble pas du tout raisonnable ! Pourtant, je ne suis vraiment pas très chaud pour le lancer directement dans la pente sans avoir pu effectuer auparavant quelques réglages. Alors je me permets de m'adresser à eux à travers ton post pour savoir comment ils procèdent pour le tout premier vol...
Bons futurs tests .
Posté le: 28/03/2017 21:55 Sujet du message: |
Thanks a lot Michel, Sebastian and Sed for all your comments and advices!
I am very glad there is little damage and in this way I learned about the weak spots of this plane! Fokker himself made also a lot of changes on this plane!
Sadly I could not do as Fokker on this picture
I knew the risks of hand launches, but there are also risks with towing or bungee.
I learned a lot of it, I'll make some changes in the wing warping and rigging and I have got the confidence now to tow it!
Vincent. |
Posté le: 29/03/2017 07:27 Sujet du message: |
Nicht kaputt machen, Vincent
Sie ist viel zu schade!
Ich mache solche Erstversuche immer mit Flitschengummi:
Erst nur mal rutschen lassen, dann immer etwas mehr vom Boden weg
steigen steigen lassen, so kann man sich drauf einstellen ohne zu viel Schaden zu verursachen (meist )
Gruß und viel Erfolg beim erneuten Erstflug
Johannes |
Posté le: 29/03/2017 08:08 Sujet du message: |
Just Beautiful! Maybe it´s good you found out where the weak parts are before you go to Retroplane 2017... Would have been even more annoying.
Surely it will look marvelous in the sky!
Greetings,
Christian |
Posté le: 29/03/2017 08:12 Sujet du message: |
I just remember a Airco D.H.2 I had built. It was a really beautiful thing, unfortunately on the maiden flifght I had to find out that my wires were not tight enough, too... They got into the Propeller and the Propeller ripped out the controll wires from thre rudder... THAT was sad....
https://www.youtube.com/watch?v=jFS4KbAURzU
More Greetings,
Christian |
Philippe26 Psycho Posteur
Posté le: 29/03/2017 09:13 Sujet du message: |
Aïe !!!
What a pity !
Sorry for you, it was a beautiful plane...
Fotor Stagiaire Posteur
Posté le: 29/03/2017 09:30 Sujet du message: |
SUPER !!!
Posté le: 29/03/2017 10:47 Sujet du message: |
Hello Johannes, Christian, Phillippe,
Sorry for your plane Christian its sad to see it happening.
Thanks all for your caring remarks!! I think the bungee thing is a very good option to make first flight attempts, it good to dose. Slopes and towing is a bit more frightening for me
Luckily there is not much damage and easy to repair. I never built a biplane with functional rigging, so I had a lot to learn. Specially the shockloads are so much higher with rigging because the whole thing is so stiff. I will replace the rigging and I already changed the servo arm of the wing warping to give greater travel, its now 7.5 degrees up and 7.5 degrees down.
Don't worry, it will be OK, at least I know its quite robust
Vincent |
Posté le: 30/03/2017 10:34 Sujet du message: |
Hallo Vincent,
kannst Du mal schreiben wieviel Spannweite und Gewicht Dein Modell hat?
Gruß Johannes |
Posté le: 30/03/2017 12:52 Sujet du message: |
Hallo Johannes,
Das sind die daten;
Some facts of the model;
span 2m 22cm
lenght 1m 45cm
wing surface 132 dm2
weight 4450 gr
wingload 33.7 gr/dm2
Im anfang hatte Ich gedacht dass die Spannweite des Originals 12 meter war, 2.40m als Model. Spater habe Ich dan entdeckt dass das Original eine Spannweite von 11.20 hatte, im Model 2.22m.
Gruss, Vincent. |
Posté le: 30/03/2017 17:07 Sujet du message: |
Danke Vincent
Und jetzt schnell wieder alles reparieren
LG Johannes |
Posté le: 04/04/2017 09:29 Sujet du message: |
Bonjour a tous,
The first thing I had to tackle was the rigging. I ordered wire for 90 kg, but it was to thick, not good for the looks . The insufficient clamping in the bushes with the 40 kg wire was the problem, the wire just slipped out. I think this was a mistake of mine. I am familiar with sailing and on sailing rigging the clamping is 100% free of slipping, so I just clamped the bushes. Now I learned to make an extra loop in the wire to get it slip free.
I replaced all the rigging, except for the rudder controls, because the loads are so much less.
Next was a new skid and I decided, (because its an vulnarable and essential part) to make a spare one.
laminating with thin CA, the thermos bottle is to keep the water for bending nice hot.
coloured with bister and merisier from "Liberon"
On top, bottom and sides I put glass roving with epoxy.
Connected with 3 M2 bolts to the fuselage
Finally I repaired the wing
So the Fokker is ready to fly again, we are going to tow it, hopefully coming weekend, the forecast is good and Rob is getting his Piper ready.
Vincent |
Posté le: 04/04/2017 09:44 Sujet du message: |
Very nice job ! I'm happy for these good news.
Congratulations !
Posté le: 05/04/2017 10:40 Sujet du message: |
Dear Vincent,
Nice repair. This plane is so beautiful.
Concerning first flights I am working as follow:
On the slope, with some nice Wind, I am running with the glider in my hands and I am "feeling" the movement. Up or down? It give you already good informations.
See you next time.
Regards.
Harold |
Posté le: 05/04/2017 12:08 Sujet du message: |
Hello Phillipe and Harold,
Thanks a lot for your encouraging comments.
A slope is certainly a good place for a first flight. Regretfully, the only slope in our region has a very nasty landing terrain, very, very small, with barbed wire around it and a lots of turbulence, with a modern glider with brakes is still tricky.
So we are going to tow it, nice flat field and I have adapted some controls, less elevator and more wing warping, so I hope for the best.
Vincent |
Posté le: 10/04/2017 08:45 Sujet du message: |
I have had the honour of witnessing the first flights of the Fokker yesterday. It was beautiful!
I't up to Vincent to tell his story, but here are the pictures and movie:
The plane had a lot of attention.
Some adjustments
Ready for takeoff
The sunlight throught the ribs is beautiful.
Vincent was a happy man!
Celebration with some eclair-like cakes.
And a special car-sticker was made.
Movie of the first flying day.
https://www.youtube.com/watch?v=bNBfcjasQuk
I have not been able to fully enjoy the view of this magnificent plane, because I've been looking at it only through my various cameras, but the resulting photos and video make up a lot for that.
Posté le: 10/04/2017 09:11 Sujet du message: |
Hello Raymond,
Thanks very much for making this wunderful film and the also the pictures
I am very glad the FG-2 flew, still some work on it, we think th c.g. is too for in front ( it flew with about 10 degrees elevator up)
But it flew! and the anemometer really turns
Vincent
Posté le: 10/04/2017 09:37 Sujet du message: |
Congratulations Vincent , the behaviour of the Fokker
FG2 seems quite good now! Nice video movie
ThomasF Incurable Posteur
Posté le: 10/04/2017 09:56 Sujet du message: |
Klasse!! |
Posté le: 10/04/2017 10:14 Sujet du message: |
BRAVO
Posté le: 10/04/2017 10:30 Sujet du message: |
Congratulations.
Beautiful flights. Very impressive.
Nice weather conditions. Good friends to help you. Also a very good pilot for the drone.
Best regards.
Harold |
Posté le: 10/04/2017 10:42 Sujet du message: |
Hi,
Very good report of these first flights, photos, films from various angles.
Great plane, great flights,
GOOD JOB !
All the best for the futur.
