Mad Doc Accro Posteur
Posté le: 31/05/2018 10:35 Sujet du message: |
Übrigens: Bei mir auf dem PC sind die Bilder ja korrekt hochkant, nur hier baut er die immer im Querformat ein. Kann man das irgendwie ändern? |
Posté le: 02/06/2018 16:42 Sujet du message: |
Hi Christian,
toll gemacht
Ein mal mit Sperrholz gebaut - immer mit Sperrholz gebaut
LG Johannes
ReiherIII Fidèle Posteur
Posté le: 03/06/2018 08:16 Sujet du message: |
Hallo Chrstian
Ich kann mich nur Anschließen! Wegen dem Sperrholz vorbiegen schau doch mal auf meinen Beitrag Hp2PL Musterle vom 20.9.217 nach. Mit den von mir verwendeten U- Profielen geht das sehr einfach.
Gruß Reiher III |
bocorvin Maniaco Posteur
Posté le: 04/06/2018 14:47 Sujet du message: |
Hello Christian,
You are making good progress, its looking good and also quite big ,
The ply work looks good, it looks like you bend it dry.
My experience (after some failures) is that if you soak the ply with boiling water, it will bend a lot easier ( Eric Spore wrote about it building the wing of his Nemere 1936 and I wrote down my experience in Nemere scale 1/6).
Good continuation!
LG,
Vincent |
Posté le: 05/06/2018 13:56 Sujet du message: |
Thank you all for your answers! I´ll have a look at the exif when I add photos next time.
Actually I poured boiling water over the part of plywood that is bended most, but as soon as I come along with my iron it is dry again...
I made some trials on how big a part pf plywood can be at once, I guess one piece of plywood should not be bigger than two fields between the ribs... Anyway, it is hard work, At present it took me one evening for 40cm on one side.... the other side will be easier as the nose is already done...
I found out that gloves to Keep away the heat are useful....
I hope that I finish the plywood-work in about three weeks...
It will be a little bit difficult to guarantee that there is no twist in the wing, because I don´t have a table big enough to fix the whole wing at once... Greetings,
Christian |
Posté le: 16/10/2019 15:45 Sujet du message: |
Hallo liebe Modellbaukollegen!
Ich weiß es ist kaum zu glauben, aber auch dieser Bau wird ein Ende finden! Alle Arbeiten an den Flächen, die mich aufhielten (und alle anderen Nebenprojekte ) sind fertig, es geht weiter. Beplankungen abgeschlossen, Servos eingebaut, Querruder eingestrakt, Check! Erledigt!
Es geht mit dem bebügeln los, exakt heute Abend nach dem Abendessen!
Die Nase entsteht nun aus der Form, die Klaus und ich eigentlich durch ein Blech pressen wollten... Sollte mir damit ein Zusammenstoss in der Luft geschehen, die Nase wird halten...
Liebe Grüße, Christian
Posté le: 16/10/2019 18:58 Sujet du message: |
Was lange währt wird endlich ...
Hi Cristian,
super das es (endlich) wieder damit weitergeht
Womit bespannst Du?
LG Johannes
Posté le: 17/10/2019 06:27 Sujet du message: |
Mit Oratex, wie eigentlich immer... irgendwann möchte ich aber auch mal ein anderes Material testen. Das nächste Projekt kommt bestimmt...
LG, Christian |
Uli Maniaco Posteur
Posté le: 20/10/2019 16:11 Sujet du message: |
Hallo Christian,
schön, dass du dieses interessante Projekt zu einem guten Ende bringst. Bin gespannt auf den nun sicher nicht mehr fernen Erstflug. Warum ist das Vorhaben, die Nase aus Blech zu ziehen nicht realisiert?
Uli |
LV Maniaco Posteur
Posté le: 20/10/2019 18:47 Sujet du message: |
« Uli » a écrit: Warum ist das Vorhaben, die Nase aus Blech zu ziehen nicht realisiert?
Uli
Jeder ist nicht so geschickt wie du
Laco |
Uli Maniaco Posteur
Posté le: 21/10/2019 09:13 Sujet du message: |
Lieber Laco,
Metall? Das ist leider gar nicht mein Ding. Aber ich kenne einen der vielleicht helfen würde. Sehen wir uns auf der Wasserkuppe?
Uli |
LV Maniaco Posteur
Posté le: 01/11/2019 11:40 Sujet du message: |
Hello Christian,
Good to see that the building of your Baby Albatros is in its final stage.
I am curious with what you are going to give the ply the right?? colour, I'll wait and see!
LG Vincent |
Posté le: 10/11/2019 11:44 Sujet du message: |
So, weiter geht es!
Warum wurde die Blechnase nicht realisiert? Wahrscheinlich hatten wir nicht das richtige Blech, es war nicht dehnbar genug und riss....
Was ist mittlerweile geschehen?
Alle Lötarbeiten an den elektrischen Leitungen erledigt.
Flächen bebügelt, Querruder und Bremsklappen angeschlagen und angesteuert und die Schleppkupplung mit dem Servo verbunden.
Außerdem habe ich die ersten Teile lackiert. Das lackieren mit rot ist ja echt was anderes als weiss, ich brauche glatt 4 Anstriche mehr um eine schöne Deckung zu erreichen...
Demnächst muss ich unbedingt mal Klaus besuchen, die Befestigungen am Alurohr für die Flächen würde ich gerne mit Ihm machen, viel zu bohren, Gewinde schneiden und so weiter... also, falls Du das hier liest, Klaus, ich ruf Dich bald an!
Ich habe mir bei Toni Clark dann noch zwei schöne Stahlrohre mit Tropfenprofil gekauft, um die Flächenstreben herzustellen. Die Ösen an den Enden der Rohre habe ich in den letzten Tagen auch aus GFK gefräst. Doku folgt!
Außerdem habe ich mit Corel Draw die Decals gezeichnet, einmal den Sternenkranz für das Seitenruder und den Albatros für das Firmenlogo. Beides lasse ich mir als Aufkleber herstellen.
Liebe Grüße,
Posté le: 10/11/2019 13:08 Sujet du message: |
bist ja richtig fleißig gewesen
Wird eine Augenweide wenn er fliegt
LG Johannes
Posté le: 10/11/2019 19:38 Sujet du message: |
Hello Christian,
Looks very good, maiden flight is coming in sight .
LG,
Vincent |
ManfredNeu Accro Posteur
Posté le: 11/11/2019 22:38 Sujet du message: |
Das wird ja ein wunderschönes Baby vom Albatros . Hast Du die Farbe gerollt oder gespritzt, Christian?
Manfred |
Posté le: 14/11/2019 21:21 Sujet du message: |
Hallo Manfred!
Ich rolle meistens. Ich kaufe mir immer wasserlösliche Farbe im Baumarkt, das stinkt nicht so und ist schnell zu verarbeiten. Ich bin mit dem Rollergebnis auch immer recht zufrieden. Sogar meine Benzin-Piper habe ich gerollt, hatte bisher keine Probleme mit Benzin und Lack... uns selbst wenn, dann roll ich halt nochmal drüber...
Jetzt gleich geh ich übrigens in den Keller, fange an die Flächen zu rollen!
Gestern ist der 5mm Stahldraht eingetroffen, den ich für die Flächenbefestigung brauche.
Ich sehe Licht am Ende des Tunnels....
Liebe Grüße , Christian |
Posté le: 22/11/2019 14:06 Sujet du message: |
Mahlzeit liebe Kollegen!
Hier das Update des Tages:
Die Flächen sind fertig gerollt.
Gestern dann habe ich Klaus besucht! Das war zum einen natürlich schön weil wir dann ein wenig klönen (bergische Sprachwendung für ein gehobenes fachliches Gespräch unter Experten), dabei etwas türkisches Carpaccio (Döner) verputzen und zum anderen natürlich den Fortschritt des Bowlus Babys vorantreiben konnten.
Wir haben also die ersten Aluschellen, die am Alurohr die Flächen aufnehmen, in Position gebracht und die Löcher und Gewinde ins Rohr gebohrt/geschnitten die nötig sind.
Dazu habe ich das Alurohr über die Höhenruderachse ausgerichtet und die Schellen mit einer Haltevorrichtunug in die richtige Position gebracht.
In Phase zwei des Abends haben wir dann den 5mm Stahldraht, der Flächen und Rumpf über die Aluschellen am Rohr und den GFK Laschen in den Flächen verbindet, mit Hitze und einer Biegevorrichtung abgewinkelt und ein Gewinde eingeschnitten, welches den Draht in der hintersten der Aluschellen fixiert. Diese Haltedrähte muss ich noch ein wenig ablängen und hier und da etwas aufhübschen, sind aber im wesentlichen fertig. Ich muss sagen, das alles hätte ich so gar nicht hin bekommen, da war ich schon sehr froh das Klaus mir geholfen hat!
Ich hoffe ich schaffe es am Wochenende diesen Bauabschnitt zu Ende bringen zu können, dann geht es an die Flächenstreben!
LG,
Uli Maniaco Posteur
Posté le: 29/11/2019 17:14 Sujet du message: |
Echte Profis am Werk! Da können sich die Ergebnisse sehen lassen. Bin gespannt auf den endgültigen Look - natürlich nicht nur am Boden. Wird bestimmt klasse.
Uli |
Posté le: 13/12/2019 14:04 Sujet du message: |
Hallo Kollegen!!!
Nachdem die grundsätzliche Flächenbefestigung geregelt war wurde es Zeit, den Vogel einmal komplett aufzubauen um die Geometrie zu überprüfen und die Strebenlängen zu definieren.
Das ging leider nicht zu Hause, so viel Platz ist da nicht...
Also, gestern zu Klaus!
Hier die Bilder, ich bin noch ganz ergriffen...
Liebe Grüße,
Posté le: 13/12/2019 15:38 Sujet du message: |
Sieht schon richtig gut aus ,Christian
Die Bude vom Klaus fast so oll aus wie meine
Olli Incurable Posteur
Uli Maniaco Posteur
Posté le: 14/12/2019 10:02 Sujet du message: |
Hallo Christian,
Glückwunsch - ein klasse Flieger ist das geworden!! Immer tolle Flüge damit, ein paar will ich miterleben. Waku? Klar!
Beste Grüße
Uli
Zu Weihnachten brauchst du nun ja nichts mehr |
Posté le: 14/12/2019 11:41 Sujet du message: |
Hallo Christian,
Sie konnen stolz auf ihren Segler sein
Vincent |
Posté le: 20/12/2019 12:06 Sujet du message: |
Vielen Dank Euch allen! Zuspruch motiviert ja auch immer!
Ich hoffe ich komme die Tage weiter, zumindest habe ich schon einmal einige Aufkleber anfertigen lassen und bekommen, die bringe ich nun auf. Bericht folgt!
Liebe Grüße!!! |
Posté le: 23/12/2019 00:27 Sujet du message: |
Sooooo, es geht weiter!
Die Stahlstreben habe ich abgelängt und die GFK Ösen eingebaut.
Dann sind die ersten Aufkleber plaziert, die großen Buchstaben auf den Flächen werden ja gepinselt.
Außerdem habe ich meine Künste als Polsterer ausprobiert, ich habe mit einem Stück Pappe, Schaumstoff und Kunstleder das Kopfpolster gebaut.
Liebe Grüße,
Posté le: 23/12/2019 05:25 Sujet du message: |
Bonjour Christian et Klaus, belle construction très jolis ces détails et la déco
