Wing spar dimensioning
ultralajt
Âge: 65 Sagittaire
MessagePosté le: 18/04/2014 13:53    Sujet du message: Wing spar dimensioning Répondre en citant
Hi!
What max G load and safety factor is reasonable to use at designing vintage scale sailplane model in scale range from about 1:3 to 1:2,5?
I am curently designing a model in 1:2,5 scale that is kind of Grunau Baby variant.
I am thinking that scale sailplane is to fly with care and thats why I chose ultimate load factor of (only) 10. Is this okay or not?
The wing spar caps are made from spruce and I use material strength:
34 N/mm2 for compression
and
64 N/mm2 for tension
What ultimate G load and material data you use for your spar caps sizing?
Mitja
Never try, never fail....
Christian_B
Âge: 72 Capricorne
Nouveau messagePosté le: 19/04/2014 20:04    Sujet du message: Répondre en citant
I think that your load factor of 10 is perfect for such gliders with spruce spars.
I have an simple excel sheet on my homepage where you can find all the material data I'm using (look under download).
ultralajt
Âge: 65 Sagittaire
Nouveau messagePosté le: 19/04/2014 20:32    Sujet du message: Répondre en citant
Thank you!
