RobertoP Fidèle Posteur
Posté le: 06/05/2012 21:21 Sujet du message: |
Hi All,
Following the sheeting of the full scale Pellicano the covering of fuselage is proceeding
Roberto
Roberto
Posté le: 07/05/2012 23:16 Sujet du message: |
Hi,
other photos
roberto
Posté le: 23/09/2012 18:17 Sujet du message: |
Hi All,
Some photos of fuselage of my Pellicano covered, with plywood.
Roberto
Posté le: 23/09/2012 18:53 Sujet du message: |
Hi Roberto,
Very beautiful work on the plywood
Posté le: 30/09/2012 21:08 Sujet du message: |
Hi Vincent,
thanks, but unfortunately my work is not so good as your work on your Musger MG9, you are so precise in the junction of various plywood panels and I really I do not understand how you can do this perfect junction.
Here enclosed other two photos of my Pellicano
Roberto
Posté le: 01/10/2012 06:08 Sujet du message: |
No problem, that's realistic like this, full size had same look
Posté le: 02/10/2012 10:06 Sujet du message: |
very Nice work Roberto, you can obtain better junctions of the panels with cutting templates prior to the cutting of the panels themselves to fit them perfectly but not too much ( it's a long work but no waste of plywood and more precise work) .
Avoid to sand too much the junction of the panels. It is worth bevelling carefully the panels and then you can determine the gap between them and there's almost no need to sand .
Posté le: 20/10/2012 20:59 Sujet du message: |
Hi All ,
Now I have concluded the covering of fuselage of my Pellicano and now I am working on karman here enclose some photos
Roberto
Posté le: 21/10/2012 09:42 Sujet du message: |
Christian |
Hibernatus Fidèle Posteur
Posté le: 27/10/2012 23:40 Sujet du message: |
Jolie construction
Les plans de joints sont très réalistes
@++ Christian
Posté le: 28/10/2012 19:42 Sujet du message: |
Hi All,
many thanks to all for the compliments, today I have concluded the covering of fuselage now I have to start with the moving part of rudder and then the wings .
Roberto
Posté le: 01/01/2013 17:38 Sujet du message: |
Hi All ,
I would like to wish to all peoples of the forum an happy new 2013, speaking about my Pellicano I have concluded the rudder and I start with the wings here some photos
Roberto
Posté le: 13/01/2013 21:51 Sujet du message: |
Hi All,
other pictures of my Pellicano,
Roberto
Posté le: 14/01/2013 09:46 Sujet du message: |
Salut Roberto !
Posté le: 14/01/2013 11:58 Sujet du message: |
Very nice building Roberto...Happy new year to you and your family.
" Ah, ces ailes en mouette.."
" Ah, these gull winged sailplanes.. ( famous sentence on Retroplane forum ) |
Posté le: 09/02/2013 21:58 Sujet du message: |
Hi All,
many thamks for the compliments here enclose other photos of Pellicano
Roberto
Posté le: 09/02/2013 23:33 Sujet du message: |
Ah, ces ailes en mouette..;! |
Posté le: 24/02/2013 22:20 Sujet du message: |
Hi All,
both wings are covered at the same level and now I have to fix the tubes with the blade.
Roberto
Posté le: 01/05/2013 18:09 Sujet du message: |
Hi All,
the first time of Pellicano outside my workshop.
Roberto
Posté le: 02/05/2013 08:42 Sujet du message: |
Dear Friend,
I am not sure, but is it possible, that you build your wong "upside down"?
Please check carefully.
Harold |
Posté le: 02/05/2013 09:46 Sujet du message: |
L'aileron de gauche semble être sur l'aile droite et vice versa!
Tom
Posté le: 02/05/2013 12:14 Sujet du message: |
Hi, All
the wings are correctly built I don’t know why but it is an optical effect. If you check with the other photos in the post you can verify that the wings are not upside down.
Roberto |
Posté le: 12/05/2013 16:26 Sujet du message: |
Hi
now the fuselage is painted
Roberto
Posté le: 12/05/2013 18:07 Sujet du message: |
Not painted ! varnished !!! |
Posté le: 05/06/2013 20:53 Sujet du message: |
Hi All,
other photos of Pellicano with the wings varnished.
Roberto
Walter L. Maniaco Posteur
Posté le: 05/06/2013 21:56 Sujet du message: |
A very nice glider with a very special charme |
Posté le: 05/06/2013 22:01 Sujet du message: |
Posté le: 19/06/2013 21:57 Sujet du message: |
Hi,
other photos of covered Pellicano.
roberto
Posté le: 20/06/2013 06:06 Sujet du message: |
Congratulation, beautiful soon maiden flight
what material for covering?
Posté le: 20/06/2013 08:19 Sujet du message: |
" Ah , ces ailes en mouette !!! " |
