RobertoP Fidèle Posteur
Posté le: 01/11/2010 22:07 Sujet du message: |
Thanks Vincent,
already download, are the photos that give me the idea to project and built the Bocian, for me the colour and the painting scheme is beautiful.
roberto |
Renato Stagiaire Posteur
Posté le: 02/11/2010 04:15 Sujet du message: |
Hi Roberto
!!! Beautiful piece of art !!!
Renato |
Posté le: 02/11/2010 22:18 Sujet du message: Simulation with XLRF5 |
Hi All,
today I have used the software XLRF5 to try to check the flight characteristics of Bocian with the profile MS retro 13%.
The wing incidence that I have chosen is of 2°.
In the two followings images it is possible to understand the with the CG placed at 67mm the model will fly at a speed of 12.5m/s that is 45 km/h. With the wing incidence of 2° the moment coefficient is zero.
In the enclosed diagram the max. glide ratio is about 28 at speed of 12.5m/s
Roberto |
Posté le: 07/11/2010 20:19 Sujet du message: |
Hi All some other photos of my Bocian
Roberto
Walter Incurable Posteur
Posté le: 08/11/2010 08:42 Sujet du message: |
Hi Roberto,
...looks really great!
I´m looking forward to see your Bocian airborne...
Paul ELLIS Fidèle Posteur
Posté le: 09/11/2010 19:14 Sujet du message: |
Beautiful workmanship Roberto
Paul
Un anglais en France |
Posté le: 21/11/2010 23:10 Sujet du message: |
Hi All
today I have concluded the covering of fusolage, here enclosed two photos of work.
Roberto
Posté le: 22/11/2010 11:21 Sujet du message: |
il n'y a pas à dire c'était un c'est beau planeur!
attention en Anglais: is the verry beautiful glidder!
Fauteuilaroulix in the Jabron river Valley!
Posté le: 28/11/2010 17:15 Sujet du message: |
Hi All,
today I have conclude the structure of fin where the horizontal tail is fixed. The fin is made by a a shaped balsa block I have some doubt if is better to make some hole in order to reduce the weight on rear part of fuselage.
Roberto
Posté le: 29/11/2010 01:00 Sujet du message: |
Hi Roberto. Beautifull work!!!
Is not a bad idea to reduce some weight in the tail. You could open some holes in the fin and the structure below the elevator, and refill the holes with foam, in order to mantaing the shape of the structure at the moment of cover it.
Renato |
Posté le: 29/11/2010 21:17 Sujet du message: |
Thanks Renato,
good idea to use foam to fill the holes.
Roberto |
Posté le: 12/12/2010 20:34 Sujet du message: Giorgio's Bocian |
Hi All,
also my dear friend Giorgio is working on my project of Bocian,
some photos of his work
Roberto
Posté le: 08/01/2011 23:00 Sujet du message: |
Hi All,
The construction of my Bocian is proceeding with the wings here enclose some photos of the right wing, now I need to start with the left wing.
Roberto
Posté le: 08/01/2011 23:12 Sujet du message: |
Hi All,
My friend Giorgio is working faster than me here enclose some photos of his Bocian.
Roberto
Posté le: 09/01/2011 11:04 Sujet du message: |
Very good job. |
Posté le: 09/01/2011 13:11 Sujet du message: |
pat'
Posté le: 09/01/2011 14:26 Sujet du message: |
Très beau planeur
Posté le: 09/01/2011 15:16 Sujet du message: |
Bocianissimmo ! |
Posté le: 09/01/2011 17:40 Sujet du message: |
beau boulot |
Posté le: 09/01/2011 19:07 Sujet du message: |
superbe |
Posté le: 23/01/2011 16:50 Sujet du message: |
Hi All,
many thanks to all, also the construction of my Bocian is proceeding slowly but proceeding, here enclose two photos, now I have to start with air brake.
Roberto
Posté le: 23/01/2011 18:08 Sujet du message: |
Good job, the main spar seems rather strong ! |
Posté le: 17/03/2011 22:19 Sujet du message: |
Hi All,
Some other photos of wings of my Bocian
Roberto
Walter L. Maniaco Posteur
Posté le: 18/03/2011 20:52 Sujet du message: |
Congratulations Roberto,
it looks very nice; properly built!
Posté le: 10/04/2011 18:10 Sujet du message: |
Hi all,
other photos of my Bocian, now I need to build the alierons.
Roberto
Posté le: 12/05/2011 22:07 Sujet du message: |
Hi All,
also the alierons are now concluded now I need to start with the cockpit.
Roberto
Grandemago Stagiaire Posteur
Posté le: 12/05/2011 22:20 Sujet du message: |
Molto bello Roberto, complimenti per la precisione e pulizia del lavoro.. |
Posté le: 18/05/2011 21:09 Sujet du message: |
Hi All again,
after the wings, I started with the cockpit, following the construction method indicated by Vincent for the Musger.
Now I start with the frames construction considering that the cockpit is composed of three parts: the fixed ahead part, the central part hinged and the rear sliding part.
Roberto
