Rusjan Apprenti Posteur
Posté le: 02/11/2010 12:19 Sujet du message: Minimoa ! |
Quite some progress was made in past few weeks ... This is the current state of the project...
Regards !
Uroš |
Posté le: 02/11/2010 13:02 Sujet du message: |
Hallo Uroš,
Sieht einfach toll aus, deine MiMo
Schade das das Holzwerk wieder verdeckt wird
Gruß Johannes |
Posté le: 02/11/2010 13:34 Sujet du message: |
« Johannes » a écrit: Hallo Uroš,
Dieses mal nicht ... Wird mit oratex natur gespannt ...
Uroš |
Orionis Incurable Posteur
Posté le: 02/11/2010 14:35 Sujet du message: |
Hi, Uros, nice building!
It's a good thing you've built its own shelter!
Fabrice |
Walter L. Maniaco Posteur
Posté le: 02/11/2010 22:51 Sujet du message: |
Hello Uroš,
your glider is really great!
Which profile do you use?
Do you have an idea which weight the modell will have?
Best regards
Posté le: 02/11/2010 23:42 Sujet du message: |
Great job, no doubt I will also build a big Minimoa one day after the one I made a few years ago at 1:3,5 scale, even if it's a great classic often built...Maybe the two seater... Which scheme did you choose for yours?
Posté le: 03/11/2010 09:53 Sujet du message: |
« Walter L. » a écrit: Hello Uroš,
Best regards
I used HQ 3.5/14 on the middle section and HQ 3.5/12 on the outside. Regarding weight, it sould be under 20kg, I guess around 17kg.
« Hecquetmarc » a écrit: Great job, no doubt I will also build a big Minimoa one day after the one I made a few years ago at 1:3,5 scale, even if it's a great classic often built...Maybe the two seater... Which scheme did you choose for yours?
It will be HB-232 design. Covered with natur oratex and painted white.
Regards !
Uroš |
Posté le: 03/11/2010 13:17 Sujet du message: |
Good job Uros
I use the same profile on my new C 25, normaly it's efficient and not too speed
Posté le: 29/12/2010 18:28 Sujet du message: Minimoa ! |
Some progress was made in past few days. Wings are almost ARC ...
still "dusty" from extensive sanding ...
Regards!
Uroš |
Posté le: 29/12/2010 19:16 Sujet du message: |
Looks great Uros
Stephan |
Posté le: 29/12/2010 19:17 Sujet du message: |
superbe |
Posté le: 29/12/2010 19:50 Sujet du message: |
Nice work, more spars on the wing than the original, afraid not to be strong enough ? But it doesn'nt matter much |
Posté le: 29/12/2010 21:18 Sujet du message: |
Salut !
Très beau travail ! Ces ailes sont très belles
Posté le: 29/12/2010 22:45 Sujet du message: |
Congratulations Uros!
It´s a really great glider....
cw Accro Posteur
Posté le: 30/12/2010 01:53 Sujet du message: |
Looking good Uros, but you need to generate more dust
cw |
Posté le: 30/12/2010 08:55 Sujet du message: |
Anyway, it will look impressive in flight, that's the purpose |
Jürgen Fidèle Posteur
Posté le: 30/12/2010 17:01 Sujet du message: |
Fantastic Uroš !!!
Olli Incurable Posteur
Posté le: 05/01/2011 21:16 Sujet du message: |
Hi Uros,
nice Job
I have a question?
What have you for a profile taken at the root,
and what a profile in the center and what is the profile of the end?
3,5/14 - 3,5/14 - 3,5/12 or 3,5/14 - ????? - 3,5/12
Best Regards Olli
www.oliver-theede-oldtimersegler.de |
Posté le: 05/01/2011 22:56 Sujet du message: |
« Olli » a écrit: Hi Uros,
nice Job
I have a question?
Best Regards Olli
Hello Olli !
I took 3,5/14 - 3,5/14 - 3,5/12 .
Regards !
Uroš |
Posté le: 11/02/2011 16:32 Sujet du message: Minimoa ! |
Some progress on the fuselage ...
Regards !
Uroš |
Posté le: 11/02/2011 18:08 Sujet du message: |
Posté le: 11/02/2011 18:14 Sujet du message: |
Hi Uroš, great work
behind you, it's your slope to fly?
Posté le: 11/03/2011 14:56 Sujet du message: Minimoa ! |
We are slowly coming to an end ... Oratex is already prepared and some finishing touches are still to be made on the fuselage.
Regards !
Uroš |
Posté le: 11/03/2011 15:00 Sujet du message: |
Splendide, félicitations
Posté le: 11/03/2011 18:13 Sujet du message: |
Congratulations Uros, it's close to the end but still a lot of work with the finishing steps |
