IKAR Polish glider of 1925.
awiatik
Âge: 56 Scorpion
MessagePosté le: 16/04/2012 15:58    Sujet du message: IKAR Polish glider of 1925. Répondre en citant
Hi all,
Somehow I have long bore me to build a glider Polish pre-war structures, namely the pioneer period.
The scale is 1/10, is becoming quite popular in the west.
A little history:
This glider designers were Jan Kazimierz Czarnecki and Vronsky.
The glider was built in the carpentry shop in Poznan railway workshops. The glider was planned to complete before the Second Competition Glider, but unfortunately failed to finish work on time.
In the spring of 1926 years of glider made ​​a few jumps. Later dorobiono glider landing gear wheel to try to take off the car, but such attempts were not authorized. Some time later, he was corrupted and deleted.
span - 10 m
Length - 6 m
height - 1.7 m
wing area - 17 m2
excellence around 10
So much for historical trait.
design process using the "latest" technology.
Time to get on with the construction: the hull and cut templates leaf profile
strengthen the sides of the slats balsowych 3x3 mm.
Âge: 60 Scorpion
MessagePosté le: 16/04/2012 18:15    Sujet du message: Répondre en citant
Hi "awiatik" welcome to the forum Very Happy if you can give us your firstname Wink
I love these originals gliders, glad to follow your building Very Happy
awiatik
Âge: 56 Scorpion
MessagePosté le: 16/04/2012 18:18    Sujet du message: Répondre en citant
Construction continued:
next step: wings...
...vertical tail
Initial submission of the whole model
covering japan tissue,
painting fusellage,
RC equipment:
Model flight very nicely, and I regret that there is a larger scale.
But the next model glider will be on a larger scale.
awiatik
Âge: 56 Scorpion
MessagePosté le: 16/04/2012 18:24    Sujet du message: Répondre en citant
Hi Vincent,
My name is Konstanty in short Kostek
Model builds on 30 years.
Âge: 60 Scorpion
MessagePosté le: 17/04/2012 11:35    Sujet du message: Répondre en citant
Hi Kostek
What is the final weight? the flight is on the slope or at a field?
awiatik
Âge: 56 Scorpion
MessagePosté le: 17/04/2012 13:13    Sujet du message: Répondre en citant
The total weight 239 grams for the flight. Trial flights I took on a little slope, then flying through the hall.
Regards
Kostek
