Fafnir 4m - Cem
czirh
Âge: 55 Sagittaire
MessagePosté le: 06/10/2009 17:17    Sujet du message: Répondre en citant
« Laurent14 » a écrit:
Hi Cem,
A nice work in DHC (in french, découpe à l'huile de coude).
In english, COE - cutting oil elbow. Wink
google translate
Merci beaucoup Very Happy Je ne comprend pas tres bien le DHC. Je n'utilise pas de l'huile pendant decoupage. Ou, est-ce c'est une expression Française?
Merci!
Cem Zırh
Fafnir
czirh
Âge: 55 Sagittaire
MessagePosté le: 06/10/2009 17:54    Sujet du message: Répondre en citant
« Stephan » a écrit:
Cem
how have you get copied the formers and ribs so properly from the plan to the play wood [humm]
Hehhehhehheeee !!! SECRET ... BIG SECRET Laughing
First, I make photocopy of the drawings. Next, I place the relevant parts/sheets (the drawing must be facing down) over the plywood/balsa. In Turkish, we say "like kissing".
Now, the important part :
You must make a little training on another sample before application ...
You must stiffly press the copy over the plywood with one hand while making the transfer to avoid any possible movement/distortion. You take a piece of cloth and wet it with "cellulosic thinner" and strongly rub it over the drawing lines which will make the transfer. The thinner should be the right amount to make a successful transfer. This is why you must make a few trials. You must DEFINITELY do this in a very well ventilated room.
You will best understand with a few trials ...
Hope this helps Very Happy
Cem Zırh
Fafnir
DirkSchipper
Âge: 61 Poissons
MessagePosté le: 06/10/2009 18:41    Sujet du message: Répondre en citant
C'est encore plus facile: te fait un photocopie ou impression laser.
Couleur noir, tres dense.
Coté copie en bas, contre le bois.
Tenir en place, passer aver un fer a repasser bien chaud.
Comme ca om peut faire deux qq fois trois copies.
In Enlish:
It's even easier.
Make a copy or laser-print. Color = black, high density.
Print-side facing the wood.
Secure the paper by hand/tape/... and pass over with a hot (flat)iron.
This way you can make at least 2, sometimes 3 copies from 1 print.
Dirk.
MessagePosté le: 06/10/2009 21:00    Sujet du message: Répondre en citant
Hi Cem,
google translate
Merci!
DHC = Decoupe a l'huile de Coude = Hand cutting
czirh
Âge: 55 Sagittaire
MessagePosté le: 06/10/2009 22:14    Sujet du message: Répondre en citant
Today..
Larex lath.
Cem Zırh
Fafnir
Âge: 54 Scorpion
MessagePosté le: 07/10/2009 06:08    Sujet du message: Répondre en citant
Yes, it's a french expression, a joke for guys who have a cnc, they are jealous Laughing
czirh
Âge: 55 Sagittaire
MessagePosté le: 07/10/2009 20:03    Sujet du message: Répondre en citant
Fuselage fotos..
Cem Zırh
Fafnir
czirh
Âge: 55 Sagittaire
MessagePosté le: 08/10/2009 12:25    Sujet du message: Répondre en citant
fotos..
Cem Zırh
Fafnir
Âge: 55 Verseau
MessagePosté le: 08/10/2009 14:18    Sujet du message: Répondre en citant
[clap] [clap] [clap] Czirh
Tu ne vas pas tarder à me rattraper bientôt Very Happy
Bon courage pour la suite [good]
DirkBoehm
Âge: 40 Balance
MessagePosté le: 14/10/2009 10:14    Sujet du message: Répondre en citant
« DirkSchipper » a écrit:
C'est encore plus facile: [...]
In Enlish:
It's even easier.
Dirk.
mais faites attention, si vous utilizees Tape pour tenir les copies en place. Ne touchez pas le Tape avec le fer.. ca veux faire des problèmes avec vos femmes.
Easier but dangerous... don't touch that tape with the iron... one could get into big trouble with his wife ;)
Aussi Dirk.
Viele Grüße,
Dirk.
czirh
Âge: 55 Sagittaire
MessagePosté le: 16/10/2009 17:29    Sujet du message: Répondre en citant
Can I use joiner, only 8mm carbon stick , is it enough? Or two?
[humm] (wingspan 4 mt)
Thank you..
Cem
Cem Zırh
Fafnir
Âge: 54 Scorpion
MessagePosté le: 16/10/2009 17:59    Sujet du message: Répondre en citant
No carbon, especially there are no struts, prefer 14mm fiberglas or rod steel
czirh
Âge: 55 Sagittaire
MessagePosté le: 17/10/2009 16:42    Sujet du message: Répondre en citant
Ok. Thank you , Vincent.
Cem Zırh
Fafnir
czirh
Âge: 55 Sagittaire
MessagePosté le: 17/10/2009 16:43    Sujet du message: Répondre en citant
Today:
Sanding job is not finished. Rolling Eyes
Cem Zırh
Fafnir
czirh
Âge: 55 Sagittaire
MessagePosté le: 18/10/2009 21:16    Sujet du message: Répondre en citant
Rudder foto:
Cem Zırh
Fafnir
Page 2 sur 12
