| Auteur | Message |
| czirh Accro Posteur
|  Posté le: 07/08/2009 19:52    Sujet du message: Aileron - servo |     |
| Can I use this servo :
 DS-929MG
 Corona Digital Servo 2.2kg / 12.5g / .11sec
 Features.
 Ball bearing support
 Programmable Digital, with MOSFET Drive
 Metal gearing
 High Speed & High Torque
 Speed: .11sec/60deg @ 4.8v
 Stall Torque: 2.2kg.cm @ 4.8v
 Standing Torque: 2.2kg.cm/5deg hold out
 Weight: 12.5g
 for the 3.3m wingspan Grunau Baby 's ailerons?
  Cem Zırh
 Fafnir
| texier Accro Posteur
|  Posté le: 08/08/2009 00:26    Sujet du message: |     |
| Hello Czirh,
 The technical datas of this servo look good (enought torque, metal geared) even I don't know this mark (quality ? ).
 Therefore I would choose a bigger one because your glider will have large and probably heavy ailerons causing relative strength (later movements) between servo and structure. With a bigger size the servo's case will be better maintened in my opinion.
 In all cases the metal geared servos are necessary with small servos.
 I remember a glider with which one I had plastic gear to replace after each landing
 Good luck
  Sylvain.
| erwan Psycho Posteur
|  Posté le: 08/08/2009 07:56    Sujet du message: |     |
| Hello
 If you have more place in the wings, take biggest servos (C5077 for exemple, it's not very expensive , more torque than DS-929 mg and better resistant for choc)
| czirh Accro Posteur
|  Posté le: 08/08/2009 18:21    Sujet du message: |     |
| Thanks , Texier and Erwan. Bigger servo is better for the ailerons.
  Cem Zırh
 Fafnir
 | Vous ne pouvez pas poster de nouveaux sujets dans ce forum Vous ne pouvez pas répondre aux sujets dans ce forum
