cw Accro Posteur
Posté le: 19/07/2009 22:40 Sujet du message: HW 4 FLAMINGO 1:3.5 SCALE |
Well, it looks like good building weather again. Blowing a gale here today, so I started cutting wood for the Flamingo. It has eveything I like: a gull wing, spoilers... and a wheel
cw |
Posté le: 20/07/2009 09:12 Sujet du message: |
Dear Chris,
Previous project not yet dry and you start already a new one. You intend to fly in September?
Seems to be an interesting subject.
Can you give some more details about this sailplane?
On the net I found a picture of one from Friedrichshafen exhibition?
http://myaviation.net/search/photo_search.php?id=01304533&size=large
Regards.
Harold |
ultralajt Fidèle Posteur
Christian_B Fidèle Posteur
Posté le: 20/07/2009 19:10 Sujet du message: |
Harold,
I would say it is a Petrel on the picture in your link and not a Flamingo!
Christian |
cw Accro Posteur
Posté le: 20/07/2009 19:14 Sujet du message: |
Elegance, yes...how could I forget!
Harold, I think that is a photo of Graham Saw's Petrel. The two gliders do look similar, but since Belair in the UK produced a kit for the Petrel, there are a lot of them about over here...!
cw |
Posté le: 21/07/2009 09:09 Sujet du message: |
Hi Chris,
The Flamingo is a beautiful and a quite unknown glider, good project !
I'm fond of the Petrel. My mini 1/10 flies so good, I think I'm gonna build a bigger one. I've thought about painting it blue with a white nose, and then I see your photos, great !!
I've seen the videos of your's in flight, it's magnificent !
Bye
Lolométéo
Posté le: 21/07/2009 09:31 Sujet du message: |
Hi Chris
Nice project, the Flamingo attracted my interest when i discovered Martin Simons' books ; The same as you,this glider has everything I like !
best regards Marc |
cw Accro Posteur
Posté le: 22/07/2009 22:44 Sujet du message: |
Yes Pat, that is very pretty...
Meanwhile, tonight I have finished cutting out all the fuselage parts...
(It still will not stop raining here
cw |
czirh Accro Posteur
Posté le: 23/07/2009 20:49 Sujet du message: |
Beautiful birth, beautiful project, Chris .
I like gull wing.
Chris, be my guest ... Today, it was almost 40 degrees C here
Cem Zırh
Fafnir |
cw Accro Posteur
Posté le: 24/07/2009 00:47 Sujet du message: |
40 degrees? Too hot to build aeroplanes...
cw |
cw Accro Posteur
Posté le: 24/07/2009 22:21 Sujet du message: |
OK, starting at the beginning, the 1st fuselage 1/2 shell is built up on the board...
cw |
cw Accro Posteur
Posté le: 26/07/2009 00:17 Sujet du message: |
Today, the other half of the fuselage is added...
cw |
cw Accro Posteur
Posté le: 30/07/2009 21:22 Sujet du message: |
To continue with the rear of the fuselage we need the tailplane...
cw |
cw Accro Posteur
Posté le: 02/08/2009 21:07 Sujet du message: |
Time now to make the smell that my wife hates...
Then, the wing joiner box: Two 14mm Graupner brass boxes set for the dihedral and with the boxes crossing over each other to get the maximum length
The completed box is temporarily offered up to the fuselage
cw |
cw Accro Posteur
Posté le: 05/08/2009 19:34 Sujet du message: |
Now the front end is completed...
It is time to work out how the tailplane will sit...
cw |
cw Accro Posteur
Posté le: 06/08/2009 23:18 Sujet du message: |
Time to make up the elevator...
The elevator is made slightly larger than the tailplane and then sanded to match it exactly...
Here the trailing edges are sanded down...
cw |
cw Accro Posteur
Posté le: 08/08/2009 23:28 Sujet du message: |
Before glueing on the lower CTP sheeting, the rudder cable guides must be set up...
Balsa on the inside helps the cyano to grip the guide cable...
Now the sheeting can continue... (by the way, I consider the blood on the fuselage to be good luck. I have bled over most of my models )
cw |
Posté le: 09/08/2009 16:12 Sujet du message: |
Yes !
Good job, like the other times.
Lolométéo
cw Accro Posteur
Posté le: 10/08/2009 22:02 Sujet du message: |
Now it is time to make up the elevator actuator...
I have modified my system slightly: now, I make the inside square brass tube 2 sizes smaller than the outside one. This makes setting up much easier and there is less possibilty of the system binding or sticking...
cw |
Walter L. Maniaco Posteur
Posté le: 12/08/2009 18:25 Sujet du message: |
Chris,
it´s a really nice project! I would like to build this beautiful glider too....
Do you have other documents about the original glider than those in Martin Simon´s book?
regards
cw Accro Posteur
Posté le: 12/08/2009 19:29 Sujet du message: |
No Walter, I have no other useful information. This time I am producing a plan for the Flamingo, which will be published by Traplet, probably sometime early next year. There will be a canopy available and also a kit of CNC cut parts...
cw |
cw Accro Posteur
Posté le: 14/08/2009 19:48 Sujet du message: |
The fuselage sheeting in CTP is just about complete...
cw |
cw Accro Posteur
Posté le: 15/08/2009 22:05 Sujet du message: |
Moving on now to the fin...
The fin is sheeted with 0.75mm CTP
cw
cw Accro Posteur
Posté le: 16/08/2009 21:22 Sujet du message: |
The fin will fit thus...
Now for the rudder...
cw |
Posté le: 16/08/2009 22:49 Sujet du message: |
... your "building-speed" is amazing Chris
Stephan |
cw Accro Posteur
Posté le: 18/08/2009 00:36 Sujet du message: |
Stephan, the more you do, the less you have to think about it...
cw |
cw Accro Posteur
Posté le: 18/08/2009 17:47 Sujet du message: |
Now that the tailplane/rudder/fin are completed...
It is time to complete the fuselage
cw |
cw Accro Posteur
Posté le: 20/08/2009 22:31 Sujet du message: |
The filling and sanding of the fuselage is coming along well...
The tail skid is lined with Lithoplate
Rear end just about complete
cw |
tibor kertesz Stagiaire Posteur
Posté le: 21/08/2009 06:49 Sujet du message: flamingo |
helllo chris, the lithoplate seems to aluminium? or titanium? |
