Rusjan Apprenti Posteur
Posté le: 15/10/2009 21:04 Sujet du message: Minimoa ! |
Some more progress...
tow hook...
from inside...
some more work done in wing-fuselage area...
prepared for finsh...
Nose still needs to be closed. Models for nose weights are already prepared and will be casted as soon as plaster moulds dry out.
Regards !
Uroš |
Posté le: 18/10/2009 18:36 Sujet du message: Minimoa ! |
Today some work was done on the air brakes...
Regards !
Uroš |
Posté le: 28/10/2009 21:46 Sujet du message: Minimoa ! |
Some more work done ...
the garden looks rather small now ...
Regards !
Uroš |
Klaus69 Apprenti Posteur
Posté le: 29/10/2009 09:43 Sujet du message: |
Well done! It looks realy nice. Hope we will see pictures from the maiden flight |
Peter64 Maniaco Posteur
Posté le: 29/10/2009 11:35 Sujet du message: |
Hallo Uros,
perfect work that you have made, .
Geetings Peter |
Posté le: 29/10/2009 21:14 Sujet du message: Minimoa ! |
Thanks, guys ... There will sure be some more photos and hopefully also the video of the maiden flight ...
Regards !
Uroš |
Posté le: 04/11/2009 22:29 Sujet du message: Minimoa ! |
Lead weights in the nose...
and finish...
Regards !
Uroš |
Posté le: 05/11/2009 21:21 Sujet du message: |
Hallo Uros,
tell me please, how much gram are the weight in the nose?
Peter |
Posté le: 05/11/2009 21:57 Sujet du message: Minimoa ! |
Hello Peter !
All 4 pieces are just a few grams below 1kg...
Regards !
Uroš |
DirkBoehm Apprenti Posteur
Posté le: 05/11/2009 22:50 Sujet du message: |
Hello Uros,
beautiful piece of work, that you present here.
I love those gullwing sailplanes.
Keep up the good work and let us know about any progress.
Cheers,
Dirk.
BTW: Almost as impressive as the Minimoa is your lawn. Nice grass, just like on a golf course. I wish mine would look half that good
Viele Grüße,
Dirk. |
Posté le: 02/12/2009 09:54 Sujet du message: Minimoa ! |
Wings are almost ARC ... Still some work sould be done on the wing tips and front end of the wing...
Regards !
Uroš |
Posté le: 25/02/2010 15:21 Sujet du message: Minimoa ! |
Almost finished ... There is still some work regarding fuselage but I hope it will be done in next days...
Regards !
Uroš
Posté le: 25/02/2010 21:37 Sujet du message: |
Salut Uros,
your glider looks like perfect .
congratulations
Peter |
cw Accro Posteur
Posté le: 26/02/2010 00:42 Sujet du message: |
Nice job, Uroš...
cw |
Posté le: 19/03/2010 01:01 Sujet du message: Minimoa ! |
Project is slowly coming to the end ...
test painting on the canopy
glass fabric on the fuselage...
filler applied...
meanwhile...
I also made "protective" bags
Regards !
Uroš |
GuillaumeG Accro Posteur
Posté le: 19/03/2010 09:54 Sujet du message: |
Hello Uros,
Wonderful job, your paint is really nice!
What did you use to cover the wings (simple oracover?)?
Guillaume |
Posté le: 19/03/2010 10:52 Sujet du message: Minimoa ! |
« GuillaumeG » a écrit: Hello Uros,
Guillaume
Yes, it's just oracover ...
Regards !
Uroš |
czirh Accro Posteur
Posté le: 19/03/2010 19:02 Sujet du message: |
Good job, Uros.
Congratulations..
Cem Zırh
Fafnir |
Posté le: 19/03/2010 19:41 Sujet du message: |
Salut Rusjan,
Trés bien mais un peu trop propre
Le prochain en CTP verni
Posté le: 19/03/2010 19:48 Sujet du message: |
Nice job Uros so it's a pity to hide the building under oracov...
Well , congratulations, next one will be more accurate !
here is mine...
Walter L. Maniaco Posteur
Posté le: 20/03/2010 00:43 Sujet du message: |
Bonsoir Marc,
c´est vrai qu´ il y a des coffrages plus transparents.
Je prefere "Koverall"
Salutations
Posté le: 20/03/2010 19:43 Sujet du message: |
Hello Uros,
You may answer our posts ! We don't want to put the shame on you ! Anyway it will fly great ,that"s the main purpose. If the sun shines bright, you 'll see a liitle the ribs even through oracover on the open parts of the wings I hope you'll enjoy it much. Let us know
best regards Marc |
Posté le: 21/03/2010 00:10 Sujet du message: Minimoa ! |
I was busy last few days, so.... I know it is not the best solution to use oracover on such "scale" model. It was "on stock" and I just wanted to finish the model asap. That may sound strange but that's how I decided. It won't be 100% scale but I hope I will enjoy flying it regardless to that. If everything goes well I hope there will be some more models done in more scale version ... |
Posté le: 21/03/2010 00:53 Sujet du message: |
Hello Uros,
your decision to cover the model this way is completely o.k.!
99,9 % of the people who will see the model will not be able to criticize anything...
It´s a very beautiful scale model and you can be proud of it.
Regards
Posté le: 21/03/2010 10:50 Sujet du message: |
Anyone is free ! I am quite sure there will be other nice models later in scale version
Will you do the maiden flight on slope or by aerotowing ? |
Posté le: 22/03/2010 14:07 Sujet du message: |
No doubt, it's a good choice ! On my Minimoa, I had to make a mixing towhook to elevator (6mm down when aerotowing) I also put a lot of diiferential on the ailerons (70% )
I hope the best for you for the first flight
Posté le: 22/03/2010 17:09 Sujet du message: Minimoa ! |
Some more work was done today on the fuselage ....
Minor things should be still done around the canopy and than ...
Regards !
Uroš |
Posté le: 22/03/2010 19:20 Sujet du message: |
You chose the old style canopy for the HB 282 and the old style rudder too... Why not...? |
