czirh Accro Posteur
Posté le: 11/03/2009 06:18 Sujet du message: |
Rudder :
Benoit1664 Accro Posteur
Posté le: 11/03/2009 07:11 Sujet du message: |
that's running well!!
( dixit ma Môman...) |
czirh Accro Posteur
Posté le: 13/03/2009 13:13 Sujet du message: |
Tail fotos...:
czirh Accro Posteur
czirh Accro Posteur
Posté le: 13/03/2009 13:15 Sujet du message: |
czirh Accro Posteur
Posté le: 13/03/2009 18:23 Sujet du message: |
Tow mechanism :
czirh Accro Posteur
Posté le: 14/03/2009 07:16 Sujet du message: |
Skid :
czirh Accro Posteur
Posté le: 15/03/2009 12:54 Sujet du message: |
I started construction of the wings.
Chris Ze Swiss Accro Posteur
Posté le: 15/03/2009 22:56 Sujet du message: |
Hello!
Nice,good and quick job !
à +, Christian
Posté le: 17/03/2009 13:08 Sujet du message: |
very good job |
czirh Accro Posteur
Posté le: 17/03/2009 18:07 Sujet du message: |
New pictures for the wings , and my assistant Biber.
czirh Accro Posteur
Posté le: 20/03/2009 13:32 Sujet du message: |
New pictures.
czirh Accro Posteur
Posté le: 21/03/2009 19:40 Sujet du message: |
Spoiler..:
czirh Accro Posteur
Posté le: 22/03/2009 15:41 Sujet du message: |
I believed first video of the first flight
spoiler works great
czirh Accro Posteur
Posté le: 23/03/2009 17:54 Sujet du message: |
Left wing & aileron..
czirh Accro Posteur
Posté le: 23/03/2009 17:59 Sujet du message: |
When I finish the model, I shall try it on the slope (I have no other alternative).
(a) Model set-ups for slope soaring?
(b) The down-up movement of aileron, elevator, rudder in cm?
(c) Any additional hints on the slope soaring for this model?
(d) Any additional reinforcement on the fuselage and wings before covering?
I shall be grateful if any of you have answers to my questions!
Thank you all in advance
Cem |
Posté le: 23/03/2009 19:13 Sujet du message: |
Hi Cem
if you can, use 2 setup with your dual rate for aileron and elevator
elevator:
small: +10mm (down) / -15mm (up)
large: +15mm (down) / -20mm (up)
ailerons:
small: +10mm (down) / -18mm (up)
large: +15mm (down) / -25mm (up)
rudder: maximum... 40/45° or 50/60mm
but these valors are not critical, Doppy is not a vicious glider
czirh Accro Posteur
Posté le: 23/03/2009 20:45 Sujet du message: |
Thank you very much , Vincent .. |
czirh Accro Posteur
Posté le: 26/03/2009 19:56 Sujet du message: |
Right aileron..
czirh Accro Posteur
Posté le: 28/03/2009 08:01 Sujet du message: |
Second video:
Tow release system..
http://vimeo.com/3884231?pg=embed&sec=
I have used standard servo. Right? Or should I use a more powerful servo? |
Posté le: 28/03/2009 08:56 Sujet du message: |
you can used standart servo but the gra....er 5077 is good for this job |
czirh Accro Posteur
czirh Accro Posteur
Posté le: 28/03/2009 15:17 Sujet du message: |
Canopy..:
czirh Accro Posteur
Posté le: 29/03/2009 17:18 Sujet du message: |
After painting canopy frame.
Posté le: 30/03/2009 05:42 Sujet du message: |
brilliant, is your canopy.......
czirh Accro Posteur
Posté le: 30/03/2009 17:57 Sujet du message: |
New canopy pictures..
Posté le: 30/03/2009 18:00 Sujet du message: |
very good
now, the more difficult is finish
czirh Accro Posteur
czirh Accro Posteur
Posté le: 31/03/2009 19:29 Sujet du message: |
I have started covering..
