Chris Ze Swiss Accro Posteur
Posté le: 04/09/2008 23:07 Sujet du message: |
Hello!
Beautiful Airplane (Jean-Marie doit baver! ), beautiful video, .... and great weather conditions too!
Bye, Christian
cw Accro Posteur
Posté le: 05/09/2008 21:57 Sujet du message: |
Merci Swiss Chris...the weather has now returned to normal, so now we must apply body filler to the tail end...
cw |
cw Accro Posteur
Posté le: 09/09/2008 18:21 Sujet du message: |
Attention now moves to the canopy...
Cutting it roughly to size. (The canopy is from my Skylark 4 mould which has fitted many models: 2-32, Minimoa, Skylark 4, Dart small & large etc)
Lining tape is used to mark out where to cut. The rule is: 'cut little and often!'
Pacer canopy glue is used to glue the canopy to the frame. Good stuff, dries out to be practically invisible
Now it is all taped down to be left overnight to dry
More body filler now to match the front of the wing fairing to the rear of the canopy...
cw |
cw Accro Posteur
Posté le: 16/09/2008 23:35 Sujet du message: |
Now work starts on some basic cockpit detailing...
cw |
cw Accro Posteur
Posté le: 21/09/2008 21:33 Sujet du message: |
Just a few more pics before the Solartex iron is warmed up...
cw |
Posté le: 22/09/2008 09:42 Sujet du message: |
Beautiful construction Chris.
And so fast, nobody understands how this is possible!
Questions;
Why the hole on top of the fin?
Why a plastic tube in the fin. You are going to install an altimeter?
Harold |
mat2verre Maniaco Posteur
Posté le: 22/09/2008 10:32 Sujet du message: |
Your doggy seems to enjoy your work... Like we do!
Matthieu
cw Accro Posteur
Posté le: 22/09/2008 22:00 Sujet du message: |
Harold, the hole in the fin is to allow the fitting of the tube for the TEK probe that connects to the variometer in the cockpit, which compensates for the glider's speed and is supposed to eliminate 'false' lift tones from the vario.
The hole is to allow the fitting and connecting of the small brass tube in the fin after the sanding and shaping process...
Matthieu, the chien is called Henri, and is glider-friendly
cw |
cw Accro Posteur
Posté le: 27/09/2008 00:06 Sujet du message: |
The airbrakes are of commercial design and have been recessed into the wing so that they are flush to the surface. To iron the Solartex into the openings, a piece of wing joiner bar is heated up with a gas torch and used to iron the 'Tex into place...
For the ends, a piece of square brass tube does the same job...
cw |
cw Accro Posteur
Posté le: 30/09/2008 22:00 Sujet du message: |
To cope with the undercamber of the HQ profile, the Solartex is pricked through and thin cyano placed over the holes to glue the fabric to the ribs. Then, a strip of Solartex tape is ironed over the holes...
cw |
Posté le: 01/10/2008 12:55 Sujet du message: |
Chris,
Your tip is so interesting, but one think is not clear for, sorry
Do you perform this action (pricking and glueing) after stretching the solartex on the wing or before?
Thank for answer
cw Accro Posteur
Posté le: 01/10/2008 19:41 Sujet du message: |
Pat, 1st, you must iron the 'Tex to the rib. You run the iron across the rib with one hand and follow with a cloth pressed down to hold the 'Tex to the rib as the adhesive cools down.
This takes two hands, so no photograph!
Then you continue as I described above...
cw |
cw Accro Posteur
Posté le: 04/10/2008 22:08 Sujet du message: |
Today I have Solartexed the fuselage. Now I am brushing 2-pack primer over the 'Tex joins...
cw |
Posté le: 05/10/2008 20:47 Sujet du message: |
Hello,
for your job!
Please can you tell me what product you are using whens you said "car body filler" ?
I have already heard of it, but never of its name and see an image of it's box?
Could you do this for me?
As you can understand I am beginer and I am looking for data informations to collect, and to prepare me to be ready when it will be necessary.
Thanks in advance,
Regards,
Jean-Claude RIBIERE.
--> Ici c'est chez moi :
http://modelisme.jcr.free.fr/
cw Accro Posteur
Posté le: 05/10/2008 21:10 Sujet du message: |
Bon soir Jean-Claude... There are many different manufacturers of polyester filler, this is the one I use. In this instance for coarse sanding it is best to use 40 grit sandpaper while it is still soft, usually 5-10 minutes at room temperature. Then you can use 80 grit to get the correct shape, and 120 grit for areas ready to be primed...
cw |
cw Accro Posteur
Posté le: 10/10/2008 23:30 Sujet du message: |
Once the primer has been brushed on, a light coat of black aerosol paint is applied to act as a guide coat...
When you start to rub the primer down, the black will show up in the low spots. Once all the black has been rubbed away, the surface will be smooth and free of blemishes...
Now the white 2-pack paint has been applied to the fuselage
cw |
cw Accro Posteur
Posté le: 19/10/2008 17:03 Sujet du message: |
Voila, the Dart 17R is nearly completed...
Maintenant, le premier vol....!
cw |
GuillaumeG Accro Posteur
Posté le: 19/10/2008 19:32 Sujet du message: |
Beautiful Chris!!! So I'm sure it flies great We are waiting for the video |
Posté le: 20/10/2008 17:11 Sujet du message: |
Oouahhh.....
a lot of this month with two " meister " buildings
Paul ELLIS Fidèle Posteur
Posté le: 20/10/2008 18:48 Sujet du message: |
As usual a superb build Chris.
Thanks for all the tips, I've stolen most of them for the Minimoa.
Paul
Un anglais en France |
Fabrice Apprenti Posteur
Posté le: 20/10/2008 21:07 Sujet du message: |
It's beautiful.
Fab |
Posté le: 21/10/2008 16:38 Sujet du message: |
Where's the tug ? Barry ! It's time!!!
Congratulations, i assume that the flight test will be a simple formality...
L |
cw Accro Posteur
Posté le: 21/10/2008 21:28 Sujet du message: |
Laurent, Barry broke his tug at Pottes, he has still not yet repaired it...
A 1st flight is never a simple formality...!
Look what happened to this one
cw |
Posté le: 21/10/2008 21:54 Sujet du message: |
Fortunatly for Barry as the winter comes, less the repair is urgent...(more or less the same situation for me as I m retrofitting seriously my own tug)..but you're right, nothing is always granted !
Touch wood cross the fingers and thumbs up..
L |
loopingfred Incurable Posteur
cw Accro Posteur
Posté le: 25/10/2008 18:22 Sujet du message: |
So, this morning I go to White Sheet Hill...
1st, the obligatory photographs:
Now, the premier vol... (There was no one else there, so I had to take my own photos)
The Dart flies beautifully, slow, steady and very scale-like. 7 month's work validated...I am a happy man...!
cw |
Posté le: 25/10/2008 18:37 Sujet du message: |
Congratulations Chris, your Dart is really beautiful and following the building was really interesting. Hoping you will be able to make a video soon (maybe somebody else will be better ).
Have good flights with this beauty! |
zeffus Stagiaire Posteur
Posté le: 26/10/2008 15:18 Sujet du message: |
Congratulations Chris !
It's wonderful ! And built so fast !!
Lolométéo
Posté le: 27/10/2008 07:47 Sujet du message: |
for this first fly of this wonderfull full blood plane
