A new Harbinger in Spain
Poster un nouveau sujet   Répondre au sujet    RETROPLANE.net Index du Forum -> HARBINGER
Daniel
MessagePosté le: 05/11/2007 16:32    Sujet du message: Répondre en citant
Muy bonitos....
TorresM
Âge: 83 Capricorne
MessagePosté le: 06/11/2007 11:16    Sujet du message: Hola Daniel Répondre en citant
Bienvenido al foro. Estoy a tu disposición, si en álgo te puedo servir...
Bons Vols...
Manolo
Âge: 65 Bélier
MessagePosté le: 06/11/2007 11:22    Sujet du message: Répondre en citant
Hi guys
nobody than you can follow this discussion in the forum. It would be nice if you could change to a language which at least the majority of the members could understand [arf] (german for example MDR)
Daniel
MessagePosté le: 06/11/2007 11:50    Sujet du message: Répondre en citant
Hi Stephan,
Yes I agree with you. If you read my yesterday's post I asked not to speak Spanish here (even if I whish) or a different languaje than French/English, because I think that evertybody must understand what it is being discussed....
We can always send PM.
Thanks a lot Manolo !!
Daniel
Daniel
MessagePosté le: 06/11/2007 20:46    Sujet du message: Répondre en citant
Here you have my today's progress.... do not think I'm going to take pictures of every single piece of wood cutted, it is just because it seems that we are loosing the thread of this post Very Happy
As I advise you at the beginning, it is going to be a very slooooow building, because.
1.I do not have a CNC machine, so I have to cut all the pieces by hand.
2.Not too much time to build.
3.Two kids at home.
But do not worry I think I'll be maiden it on Retroplane 2015 Laughing
Âge: 65 Cancer
MessagePosté le: 06/11/2007 20:54    Sujet du message: Répondre en citant
Daniel
Don't worry, it is not a race Wink Everybody makes on his speed, time after time with pleasure of course Wink
I find you go ahead with a good rate even you do all thinks with your hands! So, so Wink
TorresM
Âge: 83 Capricorne
MessagePosté le: 06/11/2007 21:00    Sujet du message: perdon Répondre en citant
Bien. Je seul donnais la bienvenue au forum à un nouveau membre.
Stephan, j'entends ton problème. Il est le même que j'ai devant les écrits chez l'Allemand.
Perdon, S.V.P.
Bons Vols...
Manolo
Daniel
MessagePosté le: 07/11/2007 11:08    Sujet du message: Répondre en citant
Bon Jour
I'm planning to finish cutting all the formers of the rear part of the fuselage (if I'm lucky), as well as the quille.
But I have one question:
On the formers there is a part on bottom that must be removed (is for allignment) after the fuselage is finished (and before covering it), and I think it must be pre cutted in some way because if not, it will be difficult after all is glued. See attached sketch
Am I right? Or do you have any other suggestion?
Thanks in advance
Daniel
PS Stephan/Manolo, let's calm down....we all have good willing but sometimes is unavoidable to turn to your own languaje Wink
Âge: 65 Bélier
MessagePosté le: 07/11/2007 12:19    Sujet du message: Répondre en citant
« Daniel » a écrit:
...On the formers there is a part on bottom that must be removed (is for allignment)...
exactly as you said, it's for allignement and has to be removed
it is better to cover what ever is possible to cover before cutting them, thus you can avoid any distortion
« Daniel » a écrit:
...and I think it must be pre cutted in some way because if not, it will be difficult after all is glued.
...yes, the formers from Vincent have a slight pre cut, thus no problem for the final cut
Daniel
MessagePosté le: 07/11/2007 12:32    Sujet du message: Répondre en citant
Danke Stephan Very Happy
Âge: 65 Bélier
MessagePosté le: 07/11/2007 12:54    Sujet du message: Répondre en citant
con mucho gusto! [humm] Laughing
Poster un nouveau sujet   Répondre au sujet    RETROPLANE.net Index du Forum -> HARBINGER Toutes les heures sont au format GMT + 2 Heures
