ultralajt Fidèle Posteur
Posté le: 25/01/2008 10:55 Sujet du message: |
Hi!
The name of this sailplane was UTVA (Shelduck)
The latin name of the bird is: Tadorna tadorna
This sailplane was very advanced for its time, (regarding the design and manufacturing) as it is obviously also from the drawing.
I think, that more about that sailplane can be found in some of early books of Boris Cijan: Vazduhoplovno jedriličarstvo.
I have only this text regarding the Utva sailplane:
(I am translating from Serbian language-cyrillique, and article was written in Yugoslav aviators magazine KRILA (Wings) in december of 1948)
Designer: Ing. Miljenko Mitrović.
Year of manufacturing 1939.
It is cantilever mid wing. Wing with one spar. Torsion nose covered in plywood. Fuselage in oval cross section, covered with plywood.
Tail feathers of cantilever design, partly covered with ply and partly with fabric.
Wing with "W" shape. Ailerons in two parts.
The sailplane was by design one of the most interesant and newest on the world. It was way ahead of our knowledge about flight tactics.
Sailplane was equipped with landing flaps, dive air brakes, retrastable landing gear, which act regardless of the fuselage attitude, and it was able to set the landing angle depending on the weight. The landing wheel was equipeed with a brake.
Under main wing attachment point in the fuselage, there was a water balast reservoir with 40 l of capacity. Water was suppose to act as ballast to increase wing loading, for flights in very good thermal conditions.
Water could be jetison in flight if needed.
Very interesant was a design of pilot seat with rudder pedals that could be set to pilot comfort during the flight.
Cockpit canopy was made from one piece of plexi glass.
There was one combined lever for acutating the landing flaps and wheel brake.
Prototype was very comfortable and nice for flying, but the landing was hard regarding the speed and low visibility.
This prototype was tested before WW2 in Vršac.
After war was ended, there were some flights done, but considering the age of material, no further flights were conducted.
If we compare this sailplane wit the most modern sailplanes (NOTE FROM STRANSLATOR: ATRICLE WAS WRITTEN IN 1948), for instance W.L.M-1, Swiss glider, which has same airfoil NACA 23012, water ballast tank and other technical details, in many ways is similar with UTVA. Utva was desingned in 1939 and W.L.M. in 1947-1948.
My 10 cents
Regards!
Mitja
Never try, never fail.... |
beat.galliker Fidèle Posteur
Le Barde Apprenti Posteur
Posté le: 23/04/2008 09:33 Sujet du message: Identification Planeur |
Suite au message de A60 Lima India du 25/O8/2007 par lequel Pascal présente la photo d’un planeur pour identification, je peux apporter quelques informations :
Pascal dit qu’il semblerait que la photo vienne de Grèce, mais sans garantie…
Il a raison : ce cliché est présenté sur le site « Hellenic soaring archive » pour les années 30.
(on peut accéder à ces informations directement à partir de Yahoo).
Mais le planeur en question n’est pas le « Balilla » (comme le suggère ClaudeL dans son message du 28/08/2007)… c’est un « Grüne Post ».
En effet, la légende qui accompagne cette photo précise : The day before the outbreak of WW2 in Greece (27.10.40), Pangakis and Papamatheakis flew consequatively a Gruene Post in Thessaloniki for what was then long duration flights. Here, G. Pangakis is seen ready to take off.
Pour confirmer, je signale qu’on peut trouver par ailleurs, sur le forum de RETROPLANE.net, sous le sujet « Der Grüne Post », le plan-trois vues et des photos de ce type d’appareil, fournis par José Navarrete dans son message du 09/06/2007 : il y a la photo du « Grüne Post » du Musée de la Wasserkuppe et celle (qu’on peut trouver aussi sur le site de Hellenic soaring archive), dont la légende précise : « Alexandros Audis with a Gruene Post during the gliding camp in Velestino where more then 40 gliders were gathered (june 1940). »
… et pour la petite histoire, rappelons l’origine du projet :
En 1932, un journal de Berlin, le « Gruene Post », proposa de financer une étude pour la construction d’un planeur simple et pratique, à l’intention de la jeunesse allemande.
C’est Alexander Lippisch (ingénieur au sein du Rhön Rossiten Gesellschaft à la Wasserkuppe) qui en fit l’étude et en dessina les plans.
Le premier vol du prototype fut effectué en novembre 1932 aux mains de Fritz Stamer (chef pilote-instructeur à la Wasserkuppe) qui fit un rapport élogieux sur les caractéristiques de vol du planeur, ce qui encouragea A. Lippisch à en éditer les liasses de construction.
À partir de quoi, chaque fois qu’un constructeur était intéressé pour construire ce type d’appareil, le journal sponsorisait les travaux, en lui attribuant une somme suffisamment importante pour qu’il ne reste qu’un faible pourcentage des dépenses à sa charge.
Plusieurs « Grüne post » furent construits, tant en Allemagne qu’à l’étranger, (notamment, une photo de Imre Mitter témoigne de la présence de ce type de planeur en Hongrie… et le dernier exemplaire connu en état de vol fut celui, utilisé en Suisse sous l’immatriculation HB-131, dont on trouve encore la trace sur les Registres suisses à la date du 1er janvier 1948 ).
Pour ce qui est du « Grüne Post » qui a volé aux mains de Pangakis et Papamatheakis, il n’avait par forcément été construit en Grèce… (rappelons que les pilotes grecs de ces époques ont utilisé assez couramment des appareils d’origine étrangère (tels que les planeurs « Cavka » et « Roda » yougoslaves, entre autres, pendant les années 40).
Il serait donc possible que le « Grüne Post » de la photo présentée par Pascal ait été un planeur importé… (reste à savoir à partir de quel pays ?…)
… Et pour en revenir au « Balilla » évoqué par ClaudeL et à la photo de cet appareil que Jean-MarieM a trouvée sur le site de l’ami Vincenzo Pédrielli, on peut remarquer, effectivement, une très grande ressemblance entre les deux appareils, mais on peut cependant noter quelques différences assez nettes : l’avant du fuselage est nettement moins camus sur le « Balilla » et le pylône de fixation des ailes à l’emplanture est beaucoup plus mince sur le planeur italien que sur le «Grüne Post »… Le contour de l’habitacle n’est pas tout à fait de la même forme non plus et les bords marginaux des ailes sont différents (plus aérodynamiques sur le planeur de L. Teichfuss).
On pourrait peut-être avancer l’hypothèse que ce dernier ait pu construire le planeur allemand sous licence (tout en y apportant quelques petites touches personnelles), ou encore, qu’il se soit fortement inspiré du « Grüne Post » pour concevoir son « Balilla »…
J'ai d’ailleurs lu quelque part que « Balilla » signifiait « Brave Young Man », ce qui (en français dans le texte!) donnerait «Jeune Homme courageux »… ce qui pourrait confirmer l’esprit dans lequel le « Grüne Post » fut conçu…
J'espère ne pas vous avoir trop "gavés" avec ma prose...
Amitiés, Claude
Arpagaus Stagiaire Posteur
Posté le: 24/08/2019 19:21 Sujet du message: Quel est ce planeur ? |
Bonjour je souhaiterais connaître le nom de ce planeur
D'avance merci de votre aide. ;0))
Olli Incurable Posteur
